cloudy
Author Topic: Detecting Cloudy or Clear night  (Read 89646 times)
Offline BrianM
  • High Wycombe, Bucks
    • http://www.flackwellheath.net
« on: September 07, 2008, 01:22:37 PM »
Hi all
I have noticed that an option for a peltier based cloud detector has been added?
Not sure where to find it?
But I have noticed that my Jam Jar Temperature Solar sensor is colder than my outside temperature sensor on clear nights and the same temperature on cloudy nights.
I assume that this is similar to a peltier sensor.
Could my temperature difference on a clear night be used to set the summary Icon & description?
Regards, Brian
Sorry I have just noticed that I have posted this in the wrong section. Oops
« Last Edit: September 07, 2008, 02:00:22 PM by BrianM »
Intel Pent Dual CPU 1.8GHz 1G RAM, Win XP Pro, Oregon WMR928N,
Bashy
  • Guest
Re: Detecting Cloudy or Clear night
« Reply #1 on: September 07, 2008, 01:40:33 PM »
I aint sure how that would work dues to different temperature nightly
Offline BrianM
« Reply #2 on: September 07, 2008, 01:54:50 PM »
Its like solar in reverse, on a clear night regardless of temperature the Temp sensor in the Jam Jar is always lower than the normal outside temp sensor.
So you could look for the difference i.e. Jam Jar & Outside the Same = "Cloudy Night", Jam Jar 1 Deg C < Ouside = "Clear Night" and somewhere in between is "Partly Cloudy"
Re Brian
Offline berdalweather
  • Martin
  • Davis VP2 Plus - Model #6163
  • Berdal, Vinje, Norway
    • www.berdalweather.net
« Reply #3 on: September 07, 2008, 02:04:22 PM »
Why would it be colder inside the jar at a clear night?
Best Regards,
Martin
Offline BrianM
« Reply #4 on: September 07, 2008, 02:15:38 PM »
Best Regards,
Martin
A very good question, I don't know, but it always is, if I take the lid off the class cover off the upside down Jam Jar so that the sensor is in free air then the temperature is the same.
I am assuming it the same / similar to how the peltier device works, both serfaces are in the same air.
Any body with a Jam Jam sensor noticed this?
Re Brain
Bashy
  • Guest
« Reply #5 on: September 07, 2008, 04:44:30 PM »
I will let you know tonight ;)
« Reply #6 on: September 07, 2008, 05:09:43 PM »
yes, thats the same principle,....i.e a black body gets colder at night (looses heat to space)
and so yes this could be used to set the cloud conditions at night as well, as being a simple night cloud detector
so, yes, I can add support for that (i.e a tick to say to use my solar in a jar sensor)
Offline BrianM
« Reply #7 on: September 07, 2008, 07:11:03 PM »
That sound great, I assume there would be an offset value as a difference?
Re Brian
Thanks for moving this thread...
Offline TokKiwi
  • Techno Dad
  • Mech Engineer and Hobbyist
  • Tokoroa, Sth Waikato, New Zealand
    • Tokoroa North Weather
« Reply #8 on: September 07, 2008, 07:17:47 PM »
Would it be possible to use a 1-wire temp sensor in this application Brian as say as a choice of extra temps (#1Extra or #2Extra or #3Extra etc) ?  It sounds very interesting!
TokKiwi
Dad's have hobbies because they are children's rugby, football and Committee Fathers!!
« Reply #9 on: September 07, 2008, 07:19:25 PM »
yes, I could add in the temperature differences to set each of the 4 night cloud conditions....
yes, Tokkiwi, any extra temp sensor can be used (albeit from 1 wire, labjack, or an actual weather station extra temp sensor)
Offline TokKiwi
  • Techno Dad
« Reply #10 on: September 07, 2008, 07:22:17 PM »
I assume we would need two side by side - one in the black jar and one free/ventilated as per normal for a difference to be caculated from.  Thanks.
Bashy
  • Guest
« Reply #11 on: September 07, 2008, 08:15:38 PM »
I have just checked my readings, my Stevenson screen is showing 13.2oC and Solar in a Jar
is reading 13.6oC and currently we have high clouds about 3000ft (Mostly cloudy) and both
sensors were checked against each other before siting it on the mast...
So with this theory, if its the same temp or the solar is higher then its cloudy,
if the solar is colder then its a clear night?
Offline TokKiwi
  • Techno Dad
« Reply #12 on: September 07, 2008, 09:29:26 PM »
As Brian said - the solar in a black jar is a "black body" and loses heat (gets colder than ambient) to a space/black sky.  I think the two sensors would need to be in the same environment, not one on a roof and the other in the garden, then you could get unusual readings.  But if the solar in a jar saw a warm tile roof (infra red re-radiated heat) then it could be warmer than a garden mounted ventilated unit at night time.
Hmmm, I see another project coming on!!  ;)
Bashy
  • Guest
« Reply #13 on: September 07, 2008, 09:57:44 PM »
Hi Graeme, my solar has no black whatsoever its just white and glass, so I aint sure if this is going to apply to my solar :(
Also mine is about 9m agl and the temp is about 2ft agl in the screen, so again, perhaps not the most ideal setup fcor this idea :(
« Reply #14 on: September 07, 2008, 10:16:32 PM »
i thought that that solar sensor in a jar was that you painted the bottom black...
