Author Topic: Hobbyboards 1wire Solar Sensor with Teperature Sensor  (Read 1115 times)
Offline TokKiwi
  • Techno Dad
  • Mech Engineer and Hobbyist
  • Tokoroa, Sth Waikato, New Zealand
    • Tokoroa North Weather
Re: Hobbyboards 1wire Solar Sensor with Teperature Sensor
« Reply #15 on: September 11, 2008, 09:15:39 PM »
Yes - that's good - that means that WD sees the various elements of the 1-wire circuit and will read in the data.  Now in the humidity sensors listed on left there should be a ROM ID. copy that and then paste it into the Solar tab, then save again and see if the solar tab developes a number.  Tick Use new calculation.
Go to the Extra temp/humidity tab and if there is a second humidity ROM ID (the same one) in there, delete that number, and go back to the Dallas main screen and save again.  Check the Solar tab for a number.
If it is dark. shine a torch on it... ;)
Once you get a number there, then you can go to the Solar Icon on Control Panel and setup things in there.  You need to enter your Long and Lat again (not if already done on that tab).
Good luck.
TokKiwi
Dad's have hobbies because they are children's rugby, football and Committee Fathers!!
Offline Whimick
  • Dorking UK
« Reply #16 on: September 12, 2008, 12:12:09 PM »
TokKiwi,
Please see below the extract from my wdisplay.ini, that shows the Rom ID's.  Does this look correct?
And should I now be able to see a temp.. reading from the sensor on extra #5?
Also dow I need to make any changes to the 1wire Port setup?  Please see image
soil moist slope=-0.0000695
Dir ROM ID=
leaf ROM ID=F5000011956B8530
Lightening ROM ID=2B0000000C8C981D
Hum ROM ID=
Temp ROM ID=BB0008018A2EA310
Extra temp ROM ID=NULL
Extra temp ROM ID 5=BB0008018A2EA310
Extra temp ROM ID 10=NULL
Extra temp ROM ID 6=NULL
Extra temp ROM ID 2=NULL
Extra temp ROM ID 3=NULL
Extra temp ROM ID 4=NULL
Extra temp ROM ID 7=NULL
Extra temp ROM ID 8=NULL
Extra temp ROM ID 9=NULL
Hum ROM ID 5=58000000B648D626
Hum ROM ID 2=NULL
Hum ROM ID 3=NULL
Hum ROM ID 4=NULL
[Dallas wind direction]
leaf wetness value 1=-0.0060
leaf wetness value 2=-0.0070
leaf wetness value 3=-0.0080
leaf wetness value 4=-0.0100
leaf wetness value 5=-0.0110
leaf wetness value 6=-0.0112
leaf wetness value 7=-0.0115
leaf wetness value 8=-0.0120
leaf wetness value 9=-0.0130
leaf wetness value 10=-0.0180
leaf wetness value 11=-0.0220
leaf wetness value 12=-0.0280
leaf wetness value 13=-0.0300
leaf wetness value 14=-0.0380
leaf wetness value 15=-0.0440
leaf wetness value 16=-0.0500
Offline TokKiwi
  • Techno Dad
« Reply #17 on: September 12, 2008, 10:32:47 PM »
Hi Wood Ant - I would shut WD down Save and Exit, then change these two around: ie, put the number where the NULL is and place NULL on the ID 5 one.
And also the humidity change 5 with 2 and then restart.
The Com Port port must be right because it works for your Lightning Counter and leaf wetness I guess.
And then restart WD, and follow my guide for the Dallas setup after that.
Here's hoping - I gotta go out now.  I hope you have some success.  I posted some screens in another thread about the solar sensor, try and find them...
TokKiwi
Offline Whimick
  • Dorking UK
« Reply #18 on: September 14, 2008, 12:44:13 AM »
TokKiwi,
Thanks for help.
I have made the changes you suggested.  What I have not worked out is WD put's this setup ROM ID's in?
Do you know if I need to place a Rom Id in the 1wire extra temp..sensor page to be able to use the 1wire sensor as ex #5?
Regards Wood Ant
Offline TokKiwi
  • Techno Dad
« Reply #19 on: September 14, 2008, 12:54:31 AM »
It's the humidity sensor you need to focus on and use that ROMID for the Solar Sensor tab of Dallas Setup. No matter which position it finds itself in.
