cloudy
Author Topic: sitemap.xml  (Read 33645 times)
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
Re: sitemap.xml
« Reply #60 on: March 26, 2009, 11:54:21 PM »
Yes..Im still fighting with my sitemap..lol i removed my robots.txt file completely to see if google would take my sitemap then, and just got this from google..
Network unreachable: robots.txt unreachable
We were unable to crawl your Sitemap because we found a robots.txt file at the root of your site but were unable to download it. Please ensure that it is accessible or remove it completely.
I dont see how google found it on my site, i removed it 2 days ago..lol
So need less to say...My sitemap is still not validating.  #-o
« Last Edit: March 27, 2009, 12:15:18 AM by ALITTLEweird1 »
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #61 on: March 27, 2009, 01:32:03 AM »
 #-o
Quote
We encountered an error while trying to access your Sitemap. Please ensure your Sitemap follows our guidelines and can be accessed at the location you provided and then resubmit.
Not unless Google is getting lost, but I dont think its too hard to find this.. http://www.snoqualmieweather.com/Sitemap.xml
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: sitemap.xml
« Reply #62 on: March 27, 2009, 01:45:42 AM »
Could it be case sensitive and need a small "s" ?
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #63 on: March 27, 2009, 01:50:12 AM »
Ive tried both...Google prefers the Capital. I just tested my sitemap through google and got this...
Sitemap: http://www.snoqualmieweather.com/Sitemap.xml         Valid Sitemap reference detected
But it wont Validate it... makes no sense to me.
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #64 on: April 02, 2009, 01:04:07 PM »
I'm not sure if this is possible, but Is there any way for someone else to test a sitemap through google to see if it works? i keep getting this error still..
URL timeout: robots.txt timeout
http://www.snoqualmieweather.com/sitemap.xml
Even If I remove the robots.txt file I get the same error. It all started when i moved to e-rice a few weeks back. i use a program to make my sitemap, and also tried the old way "link style" and google still says it has errors in it. I'm not sure if its the way I'm uploading it, or if e-rice for some reason is causing the problems. I'm just completely lost at this point. Ive tried everything possible. Now I'm blaming either e-rice or google for the problems...lol
Any help or advice on this would be great...Thanks, Mark.
Offline niko
  • syzygy
  • Global Moderator
Re: sitemap.xml
« Reply #65 on: April 02, 2009, 01:24:27 PM »
It's very strange, carterlake who started all this uses e-rice so it must work there. Maybe open a ticket with e-rice to see if you somehow got a robots.txt in the directory above /web ?
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #66 on: April 02, 2009, 01:30:49 PM »
i'll try another ticket. Last time i asked them, they said it was me. But at this point, I doubt it.
Quick question..Im at work and cant remember, is the login PW to e-rice the same as the PW you use to FTP to the site? if its not, I have to rquest a new PW to login in there from work. I sure dont want to reset the PW if it also resets the FTP password...lol
Offline niko
  • syzygy
  • Global Moderator
Re: sitemap.xml
« Reply #67 on: April 02, 2009, 01:51:46 PM »
No, FTP isn't the member login.
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #68 on: April 02, 2009, 05:48:24 PM »
i think google finally just got sick of me and accepted my sitemap..lol Ive been submitting it like 10 times a day, and just now it looks like they finally accepted it. Time will tell. Least now its telling my its sees all of the URL's in the sitemap, which it hasn't been.
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #69 on: April 02, 2009, 09:42:02 PM »
From E-Rice...
Quote
Sorry, it's due to a misconfiguration on our end. The problem should be fixed now.
E-RICE.NET SUPPORT
Offline DaculaWeather
  • Dacula Georgia
    • DaculaWeather.com
Re: sitemap.xml
« Reply #70 on: August 07, 2010, 11:35:34 AM »
I broke down and purchased a piece of of software from XML-sitemaps.com. It creates four different types of sitemaps, text, Ror, html, xml, it can include image information if you want and after completion it pings the major search engines to let them know it's available. There are about 40 different settings you can modify/customize.
I use a cron job to run this once a day.
Steve Brueck
Davis Vantage Vue VWS, v14.01p25, Weather Display, Virtual VP, StartWatch
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
Re: sitemap.xml
« Reply #71 on: August 08, 2010, 07:27:25 PM »
Hopefully you didn't pay too much for it.
too bad you have a missing xsl template that prevents you sitemap.xml from loading.
404: Page missing: http://www.daculaweather.com./pages/mods/sitemap.xsl
You really should not need a style for your sitemap.
Also, your frequency should be adjusted for each page based on what it actually does, not all set to the same like daily.
As well as the priority.  You have every page set the same which means you have no priority pages and no low priority pages.  This will prevent your site from ever getting sitelinks with Google.
an badly constructed sitemap.xml is not much better than a non-existing one.
« Last Edit: August 08, 2010, 07:32:39 PM by TNETWeather »
  • Dacula Georgia
    • DaculaWeather.com
Re: sitemap.xml
« Reply #72 on: August 09, 2010, 01:03:47 AM »
It should be http://www.daculaweather.com/generator/pages/mods/sitemap.xsl
Not sure about the priority thing, I see different priorities on the files in the sitemap file.
« Last Edit: August 09, 2010, 01:26:49 AM by DaculaWeather »
Steve Brueck
  • Mark
  • Snoqualmie,WA
Re: sitemap.xml
« Reply #73 on: August 09, 2010, 01:06:51 AM »
It should be http://www.daculaweather.com/generator/pages/mod/sitemap.xsl
Page not found.
Offline BigOkie
  • Tulsa, OK
    • East Tulsa (Douglas)
Re: sitemap.xml
« Reply #74 on: August 09, 2010, 01:18:46 AM »
A sitemap should not be a stylesheet...
You can create a stylesheet to make a sitemap human readable, but for robots to crawl pages they look for sitemap.xml or any variant of a compressed version of sitemap (sitemap.gz, etc).
If you go here:
http://www.daculaweather.com/sitemap.xml
...then it will be readable when you browse to it likely because of the xsl file you've created.  Some site authors don't wish that to be the case; it makes it too easy for others to scrape pages with easy references within.
« Last Edit: August 09, 2010, 01:21:01 AM by BigOkie »
