cloudy
Author Topic: sitemap.xml  (Read 33644 times)
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
Re: sitemap.xml
« Reply #15 on: August 31, 2008, 03:27:55 AM »
I am currently trying out the gsitecreawler and it is up to 4378 URLs and counting!  8O I think it is trying to include the entire WU through this page: http://www.cavecountryweather.com/wx13.php I paused it for now until I can figure out how to have it stop at my page.
Easy fix for gsite crawler:
click the "Filter" tab, click "add"
add your URL http://www.cavecountryweather.com/wx13.php
click "URL list" tab, click "Refresh Table" button,
highlight all your http://www.cavecountryweather.com/wx13.php URLs (you highlight many at once by click on the first one, then scroll to the last one, hold down the Shift key and click last one, they all turn yellow)
click the "Delete" button on the gsite crawler screen
now click (Re)Crawl - This Project, wait until the crawlers are idle again and then click "Refresh Table" button
Make sure all is well.
If you have the FTP settings setup in gsitecrawler you can now click "Generate - Google Sitemap-File" let it save (overwrite), then upload to FTP, then Submit to google all automatically.
Offline mdkleer
  • The Hague - Loosduinen - The Netherlands
    • Weather Station Loosduinen
Re: sitemap.xml
« Reply #16 on: September 01, 2008, 05:25:56 PM »
I use an automatic sitemap creator it's very easy to install. and i download it from http://gadelkareem.com/
Maurice
Offline Billw69
  • If you work hard, you will have time to play hard.
  • Evansville, IN U.S.A.
    • Evansville-Weather
Re: sitemap.xml
« Reply #17 on: September 01, 2008, 06:12:06 PM »
Ok, I think i did it correctly. I created and uploaded a sitemap.xml file. I then changed my robots.txt file to read as follows......
User-agent: *
Disallow: /log
Disallow: /xxx
http://www.evansville-weather.com/sitemap.xml
Is that all I need to do?
Bill
Offline lulu836
  • Linda
  • Louisiana
    • Luv Retirement
Re: sitemap.xml
« Reply #18 on: September 01, 2008, 06:15:09 PM »
The link shows me this.  In IE7 and FF.
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
Re: sitemap.xml
« Reply #19 on: September 01, 2008, 06:22:00 PM »
Bill,
Your xml file is not in the proper format.  How did you create it?
Offline Billw69
Re: sitemap.xml
« Reply #20 on: September 01, 2008, 06:23:40 PM »
I copied this site, and changed as I thought it was needed.
http://www.carterlake.org/sitemap.xml
Basically I just changed the url's and the frequency. then deleted the pages that I don't have.
« Last Edit: September 01, 2008, 06:26:36 PM by Billw69 »
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
Re: sitemap.xml
« Reply #21 on: September 01, 2008, 06:26:25 PM »
You have to look at the Source of of the page, not the output of the page as you may see it when you look at it with a browser...
There are no Dashes in the "source"
« Last Edit: September 01, 2008, 06:31:37 PM by TNETWeather »
Offline Billw69
Re: sitemap.xml
« Reply #22 on: September 01, 2008, 06:28:10 PM »
ahhh. my mistake. #-o I'll remove them, and try again.
Offline Billw69
Re: sitemap.xml
« Reply #23 on: September 01, 2008, 06:33:50 PM »
ok. Dashes are gone.
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
Re: sitemap.xml
« Reply #24 on: September 01, 2008, 06:59:18 PM »
illegal space before the xml start...
XML Parsing Error: XML or text declaration not at start of entity
Location: http://www.evansville-weather.com/sitemap.xml
Line Number 1, Column 3:
  <?xml version="1.0" encoding="UTF-8" ?>
Offline Billw69
Re: sitemap.xml
« Reply #25 on: September 01, 2008, 07:30:29 PM »
well darn it. I'll go back and delete the spaces now.
EDIT: All spaces have been removed.
Thanks for the help guys!
Bill
« Last Edit: September 01, 2008, 07:38:24 PM by Billw69 »
Offline i_fiorentino
  • 160 mls Carmignano (Po), Tuscany, Italy
    • Meteocarmignano.it
Re: sitemap.xml
« Reply #26 on: September 02, 2008, 07:30:22 AM »
Hi guys,
which metatags should i edit to have the result in attachment?
Thanks in advance,
Alessandro
Online Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
Re: sitemap.xml
« Reply #27 on: September 02, 2008, 08:54:11 AM »
This one Alessandro:
Code: [Select]
<meta name="description" content="See live weather from the Outer Hebrides in Scotland. Includes time lapse movies, forecasts and actual weather conditions updated every few seconds."> :wink:
Re: sitemap.xml
« Reply #28 on: September 02, 2008, 08:58:36 AM »
Thanks Martin!  :D
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
Re: sitemap.xml
« Reply #29 on: September 11, 2008, 12:51:11 AM »
Google is stripping the ".php"  on my Contact page Link and its saying its a bad link. As you can see in my sitemap file, it shows the .php
http://www.snoqualmieweather.com/sitemap.xml
Anyone know why Google might be doing this? Ive resubmitted my sitemap through there webtools, but that hasnt helped at all. Thanks, Mark
« Last Edit: September 11, 2008, 12:53:03 AM by ALITTLEweird1 »
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
