Author Topic: Extra Sensors for WMR100A(WMR918/68)  (Read 1020 times)
Offline CaveArnold
  • Easton, Pa
    • 3C Consulting
« on: August 26, 2008, 12:25:30 AM »
Thanks for the fix to make the extra temperature and humidity sensors work with the WMR100A similar to the WMR918/68. Two more things when you have the time. It seems that for the three extra sensors I have the current temperature and humidity is being captured. The daily low / high and low time / high time does not seem to be captured or calculated in the corresponding WMR918/68 tag. They seem to be showing the max and min temperature settings for the devices. Is this something I need to do in the configuration of the extra sensors or is it a change to the code? Below is a static look at my site or you can view it www.tricconsulting.com/weather.
I can have up to ten temperature and humidity sensors I can purchase for use with my WMR100A. I would like to add additional beyond the three extra I currently have. Are the other numbers just not shown in the tagslist.txt file or are there only 3 extra humidity and temperature sensor tags defined for the WMR918/68?
Computer Room Temperature 78.8 °F  -148.0 °F at
212.0 °F at
Computer Room Humidity 36%  -100% at
101% at
Basement Temperature 66.9 °F  -148.0 °F at
212.0 °F at
Basement Humidity 54%  -100% at
101% at
Telecom Cabinet Temperature 82.4 °F  -148.0 °F at
212.0 °F at
Telecom Cabinet Humidity 34%  -100% at
101% at
Cave
Re: Extra Sensors for WMR100A(WMR918/68)
« Reply #1 on: August 26, 2008, 04:14:15 AM »
try using the general purpose extra sensor tags (cant remember if they are available in the linux version though)
Offline CaveArnold
  • Easton, Pa
    • 3C Consulting
« Reply #2 on: August 26, 2008, 11:34:25 PM »
General purpose extra tags do not have min and max and time like WMR918/68 tags do (at least I do not see these in tagslist.txt with Linux version).
Cave
« Reply #3 on: August 27, 2008, 01:05:49 AM »
 it is available, as long as you have the clientraw updating, as
%dallasextratemp4high%
%dallasextratemp4hightime%
etc
right up to sensor 9
Offline CaveArnold
  • Easton, Pa
    • 3C Consulting
« Reply #4 on: August 28, 2008, 12:39:25 AM »
Everything worked but the following tags:
%dallasextrahum2hightime%...Dallas 1 wire 2nd humidity high time
%dallasextrahum2lowtime%....Dallas 1 wire 2nd humidity low time
%dallasextrahum3hightime%...Dallas 1 wire 3rd humidity high time
%dallasextrahum3lowtime%....Dallas 1 wire 3rd humidity low time
They filled in blanks for the times. I tried a couple of variations moving the 2 around, but neither worked. All else did work using the Dallas 1 Wire extra values for temp and hum extremes and times. The default non-numbered humidity high and low times also word from the Dallas 1 Wire extra humidity tags.
Cave
« Reply #5 on: August 28, 2008, 01:21:16 AM »
those tags are for 1 wire humdity sensors with temperature
use instead
%hiws2000sen1ht%
and
%lows2000sen1ht%
up to
%hiws2000sen9ht%
%lows2000sen9ht%
try that
Offline CaveArnold
  • Easton, Pa
    • 3C Consulting
« Reply #6 on: August 29, 2008, 12:37:44 AM »
Thanks so much , that has eliminated the problem.
Cave
