IT Farmer
Guest
« on: August 12, 2008, 11:16:44 PM » |
Got me stumped.
All is working just fine, ticking over as it should but somehow it stopped last night at 3:40am
FTPUPD.EXE started at 3:40:00 AM 13/08/08 ****agenda items to do...**** dohamweather doupload dogrouped doupload
Was the last good one, it has not worked since. I cannot say I have changed anything on the box.
Trying to fix it, I done the following: Several reboots. New WD version 10.37K version 20 Restored the wsdiplayftp.reg
But no luck,
When I do "force" the files to be created manually it works just fine. What did i mis? what got unstuck?
Thanks H.
==== edit ========
A complete new install does not do the trick either, how can I manually enforce the "agenda" ??
=== end edit===
H.
« Last Edit: September 20, 2008, 08:30:14 AM by IT Farmer »
Logged
windy
Brian
Climate Controller
OfflineLocation: West Coast Road, Awhitu Peninsular, New Zealand Station Type: Davis VP, Mac
Posts: 58,203 Local Time: Friday 06:40
« Reply #1 on: August 13, 2008, 01:55:53 AM » |
make sure you have set times to upload as well as create for each file make sure the main switch is on in the connections setup in the ftp/internet setup and that you have ticked to use weather dislay's ftpupd.exe there
any errors under view,program event log?
Logged
IT Farmer
Guest
« Reply #2 on: August 13, 2008, 02:07:11 AM » |
Ah,
ERROR: Invalid floating point operation at time/date 12:07:01 PM 13/08/08
And there are a lot of them.
Any idea?
H.
Logged
windy
Brian
Climate Controller
« Reply #3 on: August 13, 2008, 02:15:12 AM » |
some data some where is causing a maths error run the debug version which should then produce an error report (weatherd.elf )and post or email me that
Logged
windy
Brian
Climate Controller
« Reply #5 on: August 13, 2008, 03:18:28 AM » |
what was the fix? (from that thread) ?
Logged
IT Farmer
Guest
« Reply #6 on: August 13, 2008, 06:14:43 AM » |
Oh sorry,
I deleted the INF files with the date stamp of today.
Restart
rebuild from log file
an all is ok.
Thanks for following up.
H.
Logged
windy
Brian
Climate Controller
« Reply #7 on: August 13, 2008, 06:17:58 AM » |
also did you click on recreate last 31 days data file?
Logged
Bashy
Guest
« Reply #8 on: August 13, 2008, 06:46:02 AM » |
Hi Brian
Would the Debug version tell you if some thing is wrong with moviemaker in vista? Cause this is giving me the ERROR: Invalid floating point operation at time/date
I did a thread but me thinks ya not not got to it yet
Logged
windy
Brian
Climate Controller
« Reply #9 on: August 13, 2008, 09:09:26 AM » |
i have not seen that thread....I would need to set a debug version for moviemaker what is the url to that thread>?
Logged
Bashy
Guest
« Reply #10 on: August 13, 2008, 11:24:17 AM » |
Logged
windy
Brian
Climate Controller
« Reply #11 on: August 13, 2008, 07:26:34 PM » |
Logged
IT Farmer
Guest
« Reply #12 on: August 13, 2008, 08:21:49 PM » |
Sorry for the late reply, been on the road  . Yeah I re-created the last 31 days for graph etc. So far it all appears to be working ok. H.
Logged
Bashy
Guest
« Reply #13 on: August 14, 2008, 03:28:40 PM » |
Hi Brian, thanks so much for doing that but....
I had so many issues with vista, Not with WD just vista alone, I spent all last night trying to reinstall XP, and managed to sort it about 12am
Really sorry for any trouble
Logged
IT Farmer
Guest
« Reply #14 on: September 20, 2008, 08:29:25 AM » |
Well not resolved really, same error occurs again.
First time this season we have a cracker of a thunderstorm, and I am not home but no data is uploaded (appart from the clientraw.txt) this seems to happen everytime there is an extreme weather thingy. (but that is my luck I guess).
Same error again.
Also some mambo jambo about index.
ERROR: List index out of bounds (199) at time/date 7:27:59 PM 20/09/2008
Deleted all the INF files and it started uploading again, but ....... this why do this?
H.
« Last Edit: September 20, 2008, 08:33:17 AM by IT Farmer »
Logged
