I have tried it and it does show an error but it's this one for the
Contact form:
Warning: mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in D:\Web_Sites\Torro_org_uk\www\site\contact.php on line 474
The other one is a redesign of the SCWN Join.php which I'm wanting to use as a
Membership Application form but that's giving me:
Fatal error: Call to undefined function getmxrr() in D:\Web_Sites\Torro_org_uk\www\site\membership.php on line 648
I can't use the Captcha coding as the server isn't set to recognise the gdfont that's used.
The server is a dedicated server that seems to be privately owned, fortunately I do have contact with the guy who runs it. I've got the PHP specs for the site and I can PM or email the URL's to you once I get home from work if that helps? They do show that the SMTP is disabled though.
I know this is a server problem as both forms work fine on the hosted server that I use.
If you want to test either form then the membership form is set to my own email address and just pick "Martin Collins" or "Webmaster" from the dropdown on the Contact form.
Cheers
Martin.
