Author Topic: Console WMR918 issue  (Read 5158 times)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
Re: Console WMR918 issue
« Reply #15 on: August 11, 2008, 08:18:20 PM »
Ok, here's the link. That amount of data would drive you nuts on in the 'code' format here.
http://www.finn.ws/weather_data.dat
« Reply #16 on: August 11, 2008, 08:49:06 PM »
it seems like the 2 255's flags (FF) in a row are missing...
i have to head out now...though...later...
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #17 on: August 11, 2008, 09:17:46 PM »
rgr, I'm not in a hurry =)
« Reply #18 on: August 13, 2008, 09:32:35 AM »
question:
does the full x windows version work?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #19 on: August 13, 2008, 04:11:59 PM »
xorg is not installed.
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #20 on: August 13, 2008, 04:12:47 PM »
2.6.21.1 #2 Wed Sep 12 15:57:47 EDT 2007 i686 athlon i386 GNU/Linux
« Reply #21 on: August 17, 2008, 02:10:46 AM »
i think i know whats wrong
the data size of the wmr918 for the indoor data is 1 less than for the wmr968
I will make sure that is checked....
standby for a test update
« Reply #22 on: August 17, 2008, 02:32:03 AM »
ok, new update ready,vers 3.2
http://www.weather-display.com/downloadfiles/consolewd.dat
(and remove the .dat once downloaded)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #23 on: August 17, 2008, 04:01:24 PM »
Back to the way it was earlier, debug is gone, no data is being made, no log files.
Code: [Select]
*****Received count =  ----------------------------->  106
*****Received count =  ----------------------------->  27
*****Received count =  ----------------------------->  114
*****Received count =  ----------------------------->  100
*****Received count =  ----------------------------->  41
*****Received count =  ----------------------------->  43
*****Received count =  ----------------------------->  98
*****Received count =  ----------------------------->  24
*****Received count =  ----------------------------->  3
« Reply #24 on: August 17, 2008, 06:20:01 PM »
I removed the debug code (thinking it was just going to work)
back to the drawing board, but that find was one step in the right direction
you dont have a windows pc to test on the windows version do you?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #25 on: August 17, 2008, 11:20:14 PM »
The weather station in question is 3000miles away unfortunatly. I only have access via ssh2 or a bumbling old man. . aka my pops.
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #26 on: August 25, 2008, 07:18:47 PM »
anything new?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #27 on: September 03, 2008, 05:57:16 PM »
bumply. Hopefully going to get my OMAP3 chip soon but I want to make sure I've got this working on that WMR918 first. If you need to, I can get you direct access to the server. It sounds like you don't have a test station to work with.
« Reply #28 on: September 03, 2008, 09:09:41 PM »
hi, no i dont have a wmr918 (only a wmr968)
i think if you got hold of a wmr968 station it would work
not sure why you are seeing differences in the expected data output (i.e with the FF's flag data seeming to be missing)
direct access to the server would help though, or better still, if possible, a virtual com port redirect over the internet
(normaly only available in windows?)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #29 on: September 03, 2008, 09:53:04 PM »
yeah, but wmr968 stations means a couple extra hundred dollars, if I can even find one. . I'll see if I can set up a serial->eth tunnel for you.
