Author Topic: Console WMR918 issue  (Read 5157 times)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« on: August 01, 2008, 10:00:02 PM »
I've got console running on a WMR918. Since it's the same as the 968 (I thought) I've been using
Code: [Select]
Weather station type=8
I get this output
Code: [Select]
Will not run cron files
****Weather Display vers WD console 3.0****
If use this program,then please consider sending a PayPal donation to info@weath                                   er-display.com (Brian Hamilton)
www.weather-display.com
trying to open comport 1 result -> 3
*****Received count =  ----------------------------->  108
*****Received count =  ----------------------------->  33
*****Received count =  ----------------------------->  27
*****Received count =  ----------------------------->  69
*****Received count =  ----------------------------->  72
etc.
That looks right I assume. however, I'm not getting anything in logfiles nor do I get ANY data into the crons when I run them. . (Even after waiting for 1/2 hour of running the program before I do the crons. What am I doing wrong?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
Re: Console WMR918 issue
« Reply #1 on: August 04, 2008, 04:23:13 PM »
no thoughts? suggestions?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #2 on: August 08, 2008, 03:03:47 PM »
Code: [Select]
# ./GoWdconsole.sh
utc hour=15
local hour=11
8 1
Weather station type is an WMR968
Latitude= 43.0
Longitude= -73.7
Station name =Panda
Daily rain startup= 0.0
Monthly rain startup= 0.0
Will do wunderground updates
wunderground username = ********
wunderground password = ********
wunderground utc =-5
Barooffset= 0.0
Comport number= 1
Yes Revb Davis VP
Davis rain gauge .01 inch
Will do mysql updates
mysql username = ********
mysql server = ********
mysql databasename = weather
mysql tablename = wx_data
Will do mysql metric
cwop station id =
cwop call sign = -1 // -1 is default (you do not have a Ham call si
cwop latitude=
cwop longitude=
ftp server =
ftp username =
ftp port = 21
ftp remote dir =
Will do ftp passive
Will save logfile
logfile metric
Will create custom file
Custom file name =
Tag units in celsius
wind units = mph
baro metric= Y
rain metric= Y
If use this program,then please consider sending a PayPal donation to info@weather-display.com (Brian Hamilton)
*****Received count =  ----------------------------->  35
*****Received count =  ----------------------------->  106
*****Received count =  ----------------------------->  114
Anyone got any ideas? Still nothing in logfiles, I ran it for like 4 days.
Offline weatherfront
  • The Weather Shop™
  • Eastbourne, UK, MSL+5
    • The Weather Shop ®
« Reply #3 on: August 08, 2008, 04:30:15 PM »
918, 928, 968 makes no diff.
Have you checked that console power adapter is OK? Serial will not work without lains power adapter.
Also give the whole thing a long cold reboot.
The Weather Shop ® - www.weathershop.co.uk
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #4 on: August 08, 2008, 04:33:44 PM »
Well... . I originally was using my own script that I wrote to decipher the serial input. . That part worked/works just fine. Just. . I don't have the algorythm down right and sometimes it thinks the temperature is like 260 degrees. . DOUH! I'll give it a reboot but I know the serial input is working just fine.
« Reply #5 on: August 09, 2008, 09:40:47 PM »
you say you the older wmr918 instead of the new wmr968?
that will be the problem,....
i need to allow for that (station type of 3)
« Reply #6 on: August 09, 2008, 09:50:24 PM »
ok, use this udpate
http://www.weather-display.com/downloadfiles/consolewd.dat
and remove the .dat from the end after downloading
then set the station type number to 3
in the config.txt
should work now (wait a minute after data starts)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #7 on: August 11, 2008, 05:37:22 PM »
no change other than it shows up as the 918 now. . I left it running for about 2 days after installing the new consolewd and rebooting the station.
Code: [Select]
# ./GoWdconsole.sh
utc hour=17
local hour=13
3 1
Weather station type is an WMR918
Latitude= 43.0
Longitude= -73.7
Station name =Panda
wunderground username = ***********
wunderground password = ***********
Barooffset= 0.0
Comport number= 1
Yes Revb Davis VP
mysql username = ***********
mysql server = ***********
mysql databasename = ***********
cwop station id =
cwop latitude=
cwop longitude=
ftp server =
ftp username =
ftp port = 21
ftp remote dir =
Will do ftp passive
Will save logfile
logfile metric
Custom file name =
wind units = mph
baro metric= Y
rain metric= Y
*****Received count =  ----------------------------->  77
*****Received count =  ----------------------------->  64
etc
drwxrwxrwx 2 weather weather 4.0K Jun 29 16:39 logfiles
drwxrwxrwx 2 weather weather 4.0K Aug  1 19:29 datafiles
« Reply #8 on: August 11, 2008, 06:16:52 PM »
we will be on  the right track
i will add in more debug code
(also , no need to leave running that long, LOL)
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #9 on: August 11, 2008, 06:20:12 PM »
yeah, I know. I was busy doing other things over the weekend. . . like upgrading the other weather station to 2.6.24 (I'm trying to get the whole thing under 50watts)
« Reply #10 on: August 11, 2008, 07:27:17 PM »
try that download again
i have added debug code for the barometer data
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #11 on: August 11, 2008, 07:54:15 PM »
« Reply #12 on: August 11, 2008, 07:56:48 PM »
so you do not see any more info other than the data received?
Offline downbound
  • Linux Nerd
  • San Francisco, CA
    • Finn Networks
« Reply #13 on: August 11, 2008, 08:03:59 PM »
Just the
Code: [Select]
« Reply #14 on: August 11, 2008, 08:05:42 PM »
try a new download
vers 3.1 now
you should see more info
