cloudy
Author Topic: End of month july no 31st plus rain issue  (Read 5905 times)
Offline smokie
  • WS2300 operational May 2007
  • Newquay, Cornwall UK
    • Newquay weather and much more
« on: August 01, 2008, 10:22:21 AM »
Hi, losing the plot now, 2nd attempt at posting, got a problem with July end of month, there's more than one problem, here goes
no july31st
rain total for June ended at 476.1 mm but july starts at 567.9 mm ??  total on wd 72008.txt for year shows 588.6mm
Done recreate web av/ex but header is for july but all dates  and gifs refer to May,
Have put 62008.txt, 72008.txt and july2008.htm (after recreate av/ex etc) here http://www.newquayweather.com/july/
The july http://www.newquayweather.com/wxhistory.php?date=200807 is the one from last night, no 31st july and wrong rainfall total to start
Hope this all makes sense, its just one of those days
Phil
Newquay, Cornwall.UK  > WS2300 Operational since May 2007.
From 6/4/08 www.newquayweather.com
** Philip
warwickpaweather
  • Guest
Re: End of month july no 31st plus rain issue
« Reply #1 on: August 01, 2008, 10:26:26 AM »
Maybe something in WD as I'm slowly, BUT SURELY, losing my data little by little.
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« Reply #2 on: August 01, 2008, 04:15:52 PM »
Smokie my end of month went OK AFAIK, what version of WD are you using. I'm on 10.37k b16.
« Reply #3 on: August 01, 2008, 04:48:28 PM »
no problems here
try
action, convert wd logfiles to data files
select 72008lg.txt
then click on convert
then do the recreate for july
warwickpaweather, your problem was a unqiue problem
did you get my email that I needed those files .zipped (as requested), as they were striped out of the email you sent me
warwickpaweather
  • Guest
« Reply #4 on: August 01, 2008, 05:08:21 PM »
I got your email....what specific files do you want zipped and sent to you..
Offline smokie
« Reply #5 on: August 01, 2008, 07:28:31 PM »
windy,
action, convert wd logfiles to data files, where's that, have done the action > convert log files to graph ?
using 10.37 k17
phil
** Philip
warwickpaweather
  • Guest
« Reply #6 on: August 01, 2008, 07:40:58 PM »
Yeah that's missing on my version..I do have convert log files to graphs...
Offline wsw
  • Weidling near Vienna /Austria
    • Wetterstation Weidling
« Reply #7 on: August 01, 2008, 08:04:41 PM »
hi @ all,
i have a very similar problem as smokie has written. no 31st july in 2008. i´ve  converted 72008lg.txt and recreated 07/2008 3 times. no  effect,  except header is july,  on day 1 - 30 there are the values of june 2008, daily link to yyyymmdd.gif refer to may 2008. the av/ext. on bottom of the site also shows the values of may 2008
after closing an restarting wd there is the same problem. update from 10.37k b05 to b17 doesn´t help in any way!
look at www.unfried.or.at/Wetter/bastelseite.htm please, there are the log-files from 05, 06, 07/08 zipped in logtxt and the july-files recreated and  from last night zipped in july2008
thanks for the help in advance.
peter
« Reply #8 on: August 01, 2008, 08:08:58 PM »
its the same thing, my wording is not exactly the same as what you see in WD but I hope you know what I mean
warwickpaweather, its the same files that you sent already, but you need to .zip them before emailing
i.e the last31daysdata.inf and the 72008.csv logfile
Peter, .zip and email me your logfile, 72008lg.txt, and I will check/test here
Offline sm6kiw
  • Lerum, Sweden
    • SM6KIW
« Reply #9 on: August 01, 2008, 08:24:22 PM »
Hello !
I have the same problem. My logfile for july looks ok, but after i done Recreate the web av/ext page for 7 2008 under View
i still miss july 31 and the gif files are from may, see picture.
If i go direct after my recreation of the file to Detailed Climate Report under View it always change to month 5 !
Any suggestions to fix the file ? Im using 10.37k b16 from 1 of august.
I have tried a lot of things under action convert.. now my solar graph is 100% for some days..
Regards
Bo
Offline smokie
« Reply #10 on: August 01, 2008, 08:25:39 PM »
windy, No change still show may for july, calling it a day now, I will have square eyes, wide screen eyes just doesnt have that ring to it.
If I cant crack it, just will have to alter july2008.htm by hand, its funny because logfile 072008lg.txt shows correct month totals everyday, will see how Aug starts tomorrow
phil
edit
sm6kiw  thats what my page shows, may, thanks for posting gif
« Last Edit: August 01, 2008, 08:28:32 PM by smokie »
** Philip
« Reply #11 on: August 01, 2008, 08:26:24 PM »
do you see july31 data when you go to view, averages/extremes and load up month 7
also, warwickpaweather, there is a facility in WD to download your july wunderground data and import that
what is your wunderground ID?
« Reply #12 on: August 01, 2008, 08:33:22 PM »
wsw (peter)
i converted the logfile you sent me to data (graph) file
and went to view, averages/extremes, and loaded month 7
day 31 is visible
then I recreated the av/ext for July (month 7) and day 31 shows up there too OK
see
http://www.weather-display.com/July2008.htm
latest version of WD
but it is the 2nd august here, so try the excerise when its the 2nd august at your place in case that has a bearing
Offline smokie
« Reply #13 on: August 01, 2008, 08:34:25 PM »
yes windy just checked day 31 shows right up to 31 07 2008 23 59
Phil
** Philip
« Reply #14 on: August 01, 2008, 08:38:09 PM »
smokie, .zip and email me your logfile
(see my post above that it peters works Ok here, latest version of WD)
