Author Topic: WMR918 Rain Sensor TX LED always "ON"  (Read 843 times)
Offline BrianM
  • High Wycombe, Bucks
    • http://www.flackwellheath.net
« on: July 28, 2008, 10:05:24 PM »
I have a WMR 918 weather station, I noticed that the rain sensor transmitter LED is always "ON". The LED goes off when you unplug the sensor.
I have tried another TX and the same happens, I have tried a reset and checked the AA batteries.
Is this a known issue?
Is the Always "ON" an indication of something?
Any pointers would be appreciated.
Regards, Brian
Intel Pent Dual CPU 1.8GHz 1G RAM, Win XP Pro, Oregon WMR928N,
Offline gcams
  • Weather on Wheels
  • Fife, Scotland, U.K.
    • www.fifeweather.co.uk
Re: WMR918 Rain Sensor TX LED always "ON"
« Reply #1 on: August 10, 2008, 05:01:54 PM »
I had this issue a while back Brian, and discovered that there was water in the connector/cable from the rain gauge to the TX unit.  Water had actually got into the TX unit, but it was the water in the RJ-11 connector that was causing the TX light to constantly be lit (like you, I confirmed this by swapping the TX unit).
I would say there is a good chance of a short somewhere either inside the cable or inside the bucket itself.
Offline BrianM
« Reply #2 on: August 12, 2008, 06:42:02 PM »
Thanks for the reply
I believe the LED in the transmitter indicates when the sensor is drawing current, i.e. it only comes on for a short while every 60 seconds, when the sensor wakes up and sends its data.
I feel that the LED glowing (not full on) indicates that there is some leakage current on the sensor PCB, this could be due to damp or a faulty joint / component.
Mine stopped glowing after I applied some pressure to the centre of the sensor PCB.
Whilst it was glowing the sensor / transmitter continued to function correctly.
Hope this helps anybody with a similar condition.
Regards, Brian
