For the USB data logger lock up problem
Message from Davis:
We are no longer swapping dataloggers for this issue after discovering the
source of the problem and a couple of solutions.
Apparently, the issue is noise and quite a problem for any SUB device that is
constantly connected and always on.
We have found that if the user simply unplugs their AC adapter from the
console and run on the console's C batteries alone (they'll last a year and
warn you when they're low) the problem goes away.
Some customers cannot unplug their AC adapter. Sometimes they have cabled
systems and must use the AC adapter or they may exercise the datalogger
enough (5 minute internet uploads, bulletin 24/7, etc.) that the C batteries
run less than a year and makes replacement inconvenient. These users should
then use a torroid placed on the AC line, USB cable or both to filter out the
offending noise.
The torroids we used were of the type detailed at this link.
Part Number 240-2245-ND
FERRITE CYLINDER CLAMP-ON
4.5MM
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=240-2245-NDThese two methods have had great success and one should be implemented when
anyone experiences this "drop-out" problem.
