cloudy
Author Topic: CWOP server news  (Read 17808 times)
Online TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
Re: CWOP server news
« Reply #15 on: July 20, 2008, 05:30:09 AM »
I think this is correct.
« Last Edit: July 20, 2008, 05:50:54 AM by TNETWeather »
Offline Simon Cobb
  • Fendalton, Christchurch, New Zealand
    • Weather in Fendalton, Christchurch, New Zealand
« Reply #16 on: July 20, 2008, 05:32:26 AM »
Thanks, I'll give your settings a go.  Interestingly, 2 minutes after I took the above snap, I looked at my CWOP settings and found that the entries for "servers to rotate to" and "2nd servers to rotate to" had been autofilled i.e. I didn't populate either field (see attached snap).  I assume this is normal behaviour if you don't populate these fields?
Home of the Weather Display Vista weather gadget
Offline Simon Cobb
« Reply #17 on: July 20, 2008, 05:40:12 AM »
Kevin, I'm not sure if you just created that snap to show me the config, but if it's a snap of your actual config, then I think you have a typo in your setting for 2nd server to rotate to (arps instead of aprs).
Online TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #18 on: July 20, 2008, 05:47:19 AM »
never noticed that before.... Just corrected it.
Checking my connection logs...
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190652z3324.15N/11152.98W_291/004g009t093r000p000P000b10066h34L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190702z3324.15N/11152.98W_306/002g008t092r000p000P000b10066h35L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190712z3324.15N/11152.98W_307/002g009t092r000p000P000b10068h35L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190722z3324.15N/11152.98W_307/002g007t092r000p000P000b10069h37L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190732z3324.15N/11152.98W_286/001g007t092r000p000P000b10070h36L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190742z3324.15N/11152.98W_325/000g003t091r000p000P000b10073h38L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190752z3324.15N/11152.98W_325/001g002t090r000p000P000b10076h38L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190802z3324.15N/11152.98W_325/000g002t090r000p000P000b10076h41L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190812z3324.15N/11152.98W_325/002g003t089r000p000P000b10076h40L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190822z3324.15N/11152.98W_327/000g002t090r000p000P000b10078h38L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190832z3324.15N/11152.98W_327/000g001t089r000p000P000b10079h42L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190842z3324.15N/11152.98W_142/003g008t090r000p000P000b10081h38L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190852z3324.15N/11152.98W_130/000g006t090r000p000P000b10081h38L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190902z3324.15N/11152.98W_130/000g003t090r000p000P000b10081h40L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190912z3324.15N/11152.98W_130/000g002t089r000p000P000b10080h41L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190922z3324.15N/11152.98W_123/005g014t089r000p000P000b10081h43L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190932z3324.15N/11152.98W_132/004g008t089r000p000P000b10081h45L0000.WD 31
CW2582>APRS,TCPXX*,qAX,CWOP-2:@190942z3324.15N/11152.98W_142/004g008t089r000p000P000b10080h46L0000.WD 31
« Last Edit: July 20, 2008, 05:49:39 AM by TNETWeather »
