so what is the official server to use now?
IIRC you don't need to change anything in WD for this to work. Try un-ticking "Use other Server" and you should be fine. I believe Brian already made the necessary changes in WD to connect to the correct server and at the right frequency.
I agree with Dan. Windy has already upgraded WD to use
cwop.aprs.net and that automatically rotates to CWOP - 1, CWOP - 2, and CWOP - 3, which are the correct ones to use for non-Ham CWOP users. There is no need to enter the server names in manually. If you check my raw data at:
http://www.findu.com/cgi-bin/raw.cgi?call=CW0053 you will see that my packets all read that they were received by either CWOP - 1, CWOP - 2, or CWOP - 3.
EXAMPLE:
CW0053>APRS,TCPXX*,qAX,
CWOP-3:@190503z4513.10N/12123.85W_303/005g008t056r000p000P000b10156h44.WD 1
CWOP-1:@190513z4513.10N/12123.85W_320/005g009t057r000p000P000b10156h43.WD 1
CWOP-1:@190523z4513.10N/12123.85W_305/002g008t056r000p000P000b10156h44.WD 1
CWOP-2:@190533z4513.10N/12123.85W_307/000g008t056r000p000P000b10156h45.WD 1
