Wind Chill does't work
On the main display, the wind chill temperature is always the same as the “current” temperature.
I’m sure there’s a way to fix this in the menus, but I haven’t found it.
I have the same problem on 999r.
Happened between n and r.
Even with wind, the windchill is the same as temperture in the main
screen box.
Also,
Using path: View / Graph History,
the View Panel blocks the view of the Graph.
Herb
Herb, I went back to an earlier version (9.97h I believe) and still had the windchill problem.
I’ve since re-downloaded 9.99r.
It works for me with 9.99r…
[quote=“Herb”]I have the same problem on 999r.
screen box.
OK here also with 9.99r. It appears correct on my summary image, WD console and the charts.
I’m not sure what parameters Brian uses but according to the NWS :
“Wind Chill Temperature is only defined for temperatures at or
below 50 degrees F and wind speeds above 3 mph.”
