cloudy
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
You should now report bugs and problems with WDL and MML in the
Bug Tracker
. WD bugs and problems must be posted in the forum.
Latest versions:
WD
10.37Rb26
WDL
6.09
WML
1.04
Home
Bug Tracker
Photo Gallery
Wiki
Help
Search
Calendar
Login
Register
Weather-Watch.com
Weather and the Internet
CWOP & APRSWXNET
Is anyone having problems getting info to CWOP?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is anyone having problems getting info to CWOP? (Read 5722 times)
k5ilf
Las Cruces, NM USA
on:
July 04, 2008, 02:34:38 PM »
#-oHi All!
Got my system up and running with no problems, however I am unable to upload to CWOP. I was able upload, but not within the past 11 days---is this a system problem or do I still need to keep looking?
bill in las cruces
Logged
Budgie
Martin
Global Moderator
WML Station: WD00934 CWOP: CW7959
Isle of Lewis, Scotland
Re: Is anyone having problems getting info to CWOP?
Reply #1 on:
July 04, 2008, 02:48:09 PM »
I'm uploading alright and have been all day so CWOP is accepting data.
have checked your settings within WD and made sure that the APRS Upload switch is ON?
Logged
k5ilf
Las Cruces, NM USA
Reply #2 on:
July 04, 2008, 03:01:59 PM »
Well, I think I have everything setup OK (however, I must NOT as it is not working!!)
My APRS and main Internet switch are set ON
The cwop server setup is
cwop.aprs.net
with server rotation set at 23
I know it must be something simple
Thanks for your feedback.
bill in las cruces
Logged
hydrowx
Bill
Northeast Illinois USA
Reply #3 on:
July 04, 2008, 03:24:36 PM »
There have been numerous changes/suggestions to which server should be used and I think I'm using the correct one.
Here's a capture of my setup. I do use my callsign and amateur radio folks can use the server I have setup (unless things have changed again).
I'm guessing you're using your callsign vs cwop as well? If so make sure you check "I am not using a cwop id".
More info on servers
here
Last Edit: July 04, 2008, 03:36:49 PM by hydrowx
Logged
Bill
Weather Display
Reply #4 on:
July 04, 2008, 06:17:35 PM »
i know one person that had the setup, aprs wxnow.txt setup, settings, had the positionless setting set on, there (should not be)
but otherwise, what you have entered as the lat/long?
Logged
Brian
info@weather-display.com
Print
Pages: [
1
Go Up
« previous
next »
Weather-Watch.com
CWOP & APRSWXNET
