Author Topic: windspeed on the graph is not showing (plotting)  (Read 8628 times)
jumans
  • Guest
« on: December 22, 2003, 07:31:06 PM »
Hello Brian
wmr928
v.9.99p  xp pro
windspeed on the graph is not showing (plotting) and the forcast is always showing stars
help
jumans
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: December 22, 2003, 07:54:39 PM »
i did make a few mistakes with the new graph setup
check you have an option ticked for which lines to plot
(e.g use thick lines)
but 9.99q or later should fix it me thinks
forecast?
you mean from the station?
jumans
  • Guest
« Reply #2 on: December 22, 2003, 08:34:39 PM »
Thanks for the advice it worked,
The icon on the summary page always displays stars in the day time.  Should display a sun of some sort?
cheers julian
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: December 22, 2003, 08:43:39 PM »
stars:
sounds like you have some settings wrong
do you have your lat/long set correct under view, sun moon rise/set?
also check under input daily weather you do not have ticked use this icon as the main screen icon
worse comes to worse, email me your settings
wdisplay.ini and wdisplayftp.reg
to get them, go action, back up registry, click on back, then they should be in the in data back up folder, or wdisplay.ini will be in c:\windows or c:\winnt
Offline wolfe4656
  • Ravenna, Ohio, USA
Plotting Wind
« Reply #4 on: December 23, 2003, 12:37:10 PM »
Brian: I just downloaded and installed the latest beta 9.99r last night. I also have lost the wind speed plotting on the main display graph. I double clicked on the graph and tried checking the use plot thick lines but no help here. Any other suggestions.
Pent4 3.0ghz
1 gig mem
XP professional
WD
Homeseer
ws2300
Offline wolfe4656
Wind speed
« Reply #5 on: December 23, 2003, 12:47:03 PM »
Sorry Brian: I found my error. I had the use thick lines checked in the wrong window.I corrected the options  in the graph setup. All is ok now. Have a Merry Christmas.
Dave
