cloudy
Author Topic: Sunrise - Sunset PHP Script  (Read 11860 times)
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
Re: PHP code for day/night, sunrise/sunset times
« Reply #30 on: May 23, 2008, 01:11:25 AM »
Can't respond to the date you saw as that is kind of relative to when you did it.  It looked okay when I looked at it.
However, I have identified the problem with the function date_sunset.
On my server it is returning:   -4:-3
On the other server that is working, it is returning:  19:27
the PHP on my server is older so it is most likely a bug that was fixed.
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #31 on: May 23, 2008, 01:13:42 AM »
I wish I could find "moon_rise / moon_set time" PHP code, google turns up nothing.  :(
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #32 on: May 23, 2008, 01:14:52 AM »
Found a couple references to exactly what I am seeing...
Reproduce code:
<?php
echo date("D M d Y"). ', sunset time : ' .date_sunset(time(),
SUNFUNCS_RET_STRING, 40, -83, 90, -4);
Expected result:
I would expect to see:
Sun Apr 24 2005, sunset time : 20:14
Actual result:
I actually see:
Sun Apr 24 2005, sunset time : -3:-4
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #33 on: May 23, 2008, 01:15:23 AM »
That is what I was looking for.  I've got the "math" to do it, but I'm not good and converting that to PHP.
Offline MCHALLIS
« Reply #34 on: May 23, 2008, 01:19:44 AM »
Reproduce code:
<?php
Expected result:
Actual result:
I actually see:
http://bugs.php.net/bug.php?id=32820
that was fixed in PHP 5.1.2
I am running Version 5.2.5 and just realized it is time to upgrade to Version 5.2.6, wish me luck  :wink:
Offline MCHALLIS
« Reply #35 on: May 23, 2008, 01:37:22 AM »
another update in code in 1st post
Ver. 1.04 05/22/08 added php version to debugging info
Requires PHP 5 (version 5.1.3 or higher recommended, due to date_sunset bug fixes in 5.1.3)
Sample output in verbose mode:
Good day
Sunset will occur at 08:53 PM PDT
Settings and Variables:
Current PHP version: 5.2.5
May 22 2008 07:31:15 PM PDT (server time)
May 23 2008 02:31:15 AM GMT (GMT time)
myTZ = America/Los_Angeles
tzoffset = -7
lat = 46.36
long = -124.02
Zenith = 90.833333333333
Sunrise will occur at 05:31 AM PDT
« Last Edit: May 23, 2008, 01:47:50 AM by MCHALLIS »
