cloudy
Author Topic: Sunrise - Sunset PHP Script  (Read 11859 times)
Offline daveq
  • Hollywood, MD
Re: PHP code for day/night, sunrise/sunset times
« Reply #15 on: May 22, 2008, 09:53:17 PM »
Your link looks OK to me now
Good day
Sunset will occur at 08:19 pm EDT
I had two files and selected the wrong one.   #-o
As you say it is now correct.
--Dave
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
« Reply #16 on: May 22, 2008, 09:54:48 PM »
Actually, I was looking for PHP code for one of the pairs.
The two pairs were Sunrise/Sunset  and Moonrise/Moonset
I had PHP code for one of them, but never found the other.  Can't recall which pair it was now though.  Most likely the Moon ones.
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #17 on: May 22, 2008, 09:59:33 PM »
Kevin,
I see you commented the putenv("TZ=$myTZ");
try again after uncommenting it, because I tried with your settings and get "Sunset will occur at 07:27 pm MST"
Offline MCHALLIS
« Reply #18 on: May 22, 2008, 10:02:54 PM »
Farmers almanac does this:
http://www.almanac.com/rise/index.php
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #19 on: May 22, 2008, 10:22:27 PM »
Kevin,
hmmmm...
Just uncommented it out.  Still reported 8pm.
Tried again with "US/Arizona"  ... same response.
Offline daveq
  • Hollywood, MD
« Reply #20 on: May 22, 2008, 10:33:31 PM »
Maybe you need America/Phoenix
From Ken's web site
US   +332654-1120424   America/Phoenix   Mountain Standard Time - Arizona
--Dave
« Last Edit: May 22, 2008, 10:39:26 PM by daveq »
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #21 on: May 22, 2008, 10:34:51 PM »
What $tzoffset  = -8; # pacific timezone do you have?
Offline niko
  • syzygy
  • Global Moderator
« Reply #22 on: May 22, 2008, 10:37:10 PM »
  $myTZ = "US/Arizona";  //NOTE: this *MUST* be set correctly
// translate UTC times to your LOCAL time for the displays.
 putenv("TZ=$myTZ");
$latitude  = 33.40; //North
$longitude = -111.88; //West
$tzoffset  = -7; # pacific timezone
Good day
Offline MCHALLIS
« Reply #23 on: May 22, 2008, 11:00:16 PM »
I modified the script earlier today (ver. 1.02), it calculates $tzoffset automatically now based on the $myTZ setting.
I also tried his settings on my server and it was within 2 minutes of WD
"WD: Sunset 07:25 pm MST"
"PHP: Sunset will occur at 07:27 pm MST"
I wonder why my server would say 07:27 pm MST and his server 08:00 pm MST  using the same settings ????
Code: [Select]
<?php
// PHP code for day/night, sunrise/sunset times
// prints is it night or day?
// prints what time is sunrise or sunset?
// **Requires PHP 5**
// by Mike Challis http://www.carmosaic.com/
// Ver. 1.02 05/22/08 fixed timezone issue
// ##### begin settings #############
// Set the timezone for your location, because some servers are in different timezone than your location
//  http://saratoga-weather.org/timezone.txt  has the list of timezone names
$myTZ 'America/Phoenix';  // NOTE: this *MUST* be set correctly
$time_format 'h:i a T'// 08:53 pm PDT
// Set the latitude and longitude for your location
$latitude  33.4026//North
$longitude = -111.8831//West
// uncomment one zenith setting: http://en.wikipedia.org/wiki/Twilight
$zenith 90+(50/60); // True sunrise/sunset
//$zenith = 96;          // Civilian Twilight - Conventionally used to signify twilight
//$zenith = 102;         // Nautical Twilight - the point at which the horizon stops being visible at sea.
//$zenith = 108;         // Astronomical Twilight - the point when Sun stops being a source of any illumination.
// ##### end of settings #############
putenv("TZ=$myTZ");
// find time offset in hours
$tzoffset date("Z")/60 60;
$dayornight day_or_night();
if(
$dayornight == 'night') {
$sunrise date_sunrise(time(), SUNFUNCS_RET_STRING$latitude$longitude$zenith$tzoffset);
$sunrise_time date($time_formatstrtotime(date("Y-m-d") . ' '$sunrise));
      echo
'Good night<br/>';
      echo
'Sunrise will occur at '$sunrise_time;
}else{
$sunset date_sunset(time(), SUNFUNCS_RET_STRING$latitude$longitude$zenith$tzoffset);
$sunset_time date($time_formatstrtotime(date("Y-m-d") . ' '$sunset));
      echo
'Good day<br/>';
      echo
'Sunset will occur at '$sunset_time;
function
day_or_night() {
   global
$latitude$longitude$tzoffset$zenith;
$sunrise date_sunrise(time(), SUNFUNCS_RET_DOUBLE$latitude$longitude$zenith$tzoffset);
$sunset date_sunset(time(), SUNFUNCS_RET_DOUBLE$latitude$longitude$zenith$tzoffset);
$now date("H") + date("i") / 60 date("s") / 3600;
   if (
$sunrise $sunset)
      if ((
$now $sunrise) && ($now $sunset)) return "day";
         else return
"night";
   else
     if ((
$now $sunrise) || ($now $sunset)) return "day";
        else return
"night";
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #24 on: May 22, 2008, 11:09:38 PM »
Something is very weird...  It is acting like it is rounding the hour.
I updated the script so that it outputs the settings being used.
I am sneaking out of work now and will play with this a bit when I get home.
Offline niko
  • syzygy
  • Global Moderator
« Reply #25 on: May 22, 2008, 11:11:11 PM »
I think the time is off on your server:
Date: Fri, 23 May 2008 00:09:51 GMT
not that that would cause it...
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #26 on: May 23, 2008, 12:46:42 AM »
Server is time sync'd to an atomic clock.
Request from the web server returns GMT time.
Date: Fri, 23 May 2008 01:29:33 GMT
Updated the script to output its current time in GMT and each of the 4 basic US timezones...
So you can check it against your local time.
Settings:
Server Time before anything is set by script is:
Fri, 23 May 2008 01:44:56 GMT
Thu, 22 May 2008 18:44:56 MST
Thu, 22 May 2008 21:44:56 EDT
Thu, 22 May 2008 20:44:56 CDT
Thu, 22 May 2008 19:44:56 MDT
Thu, 22 May 2008 18:44:56 PDT
Local Time: Thu, 22 May 2008 18:44:56 MST
myTZ = America/Phoenix
lat = 33.4
long = -111.88
Zenith = 90.833333333333
tzoffset = -7
Good day
Sunset will occur at 08:00 pm MST
Offline TNETWeather
  • Global Moderator
  • Mesa, AZ
« Reply #27 on: May 23, 2008, 12:57:22 AM »
Put the same code on another server and it works...
Must be something about the configuration on my server.... not sure what though...
Settings:
Fri, 23 May 08 01:55:46 +0000
Thu, 22 May 08 21:55:46 -0400
Thu, 22 May 08 20:55:46 -0500
Thu, 22 May 08 19:55:46 -0600
Thu, 22 May 08 18:55:46 -0700
Local Time: Thu, 22 May 08 18:55:46 -0700
lat = 33.4
long = -111.88
tzoffset = -7
Good day
Offline niko
  • syzygy
  • Global Moderator
« Reply #28 on: May 23, 2008, 01:02:17 AM »
I understand that the server returns GMT, but if I query it at 11 minutes past the hour, GMT will also be 11 minutes past the hour, only the hour should be different, whereas it returned 00:09:51 GMT  :?  Seems to be OK now though  :? :?
Offline MCHALLIS
« Reply #29 on: May 23, 2008, 01:09:24 AM »
I saw Kevin testing with some debugging code, so I added some of that in.
changed code in 1st post
Ver. 1.03 05/22/08 added setting to print debugging info, also added a few default timezones, just uncomment what you need
