Author Topic: extra real time on beta  (Read 2824 times)
Offline hcorrin
  • Ballaugh Isle of Man GB
    • Ballaugh Weather
« on: December 06, 2003, 05:49:29 PM »
Hi Brian
The temperature part of the real time graph for extra sensors has gone off the scale on both 9.98a and b beta versions when you run the mouse across the graph i get temp readings in thousands instead of 10 or 20 deg C depending on the sensor i tried this on my laptop computer using bath beta versions not ok and 9.97h which showed graph ok log file ok in all
Main unit has WD beta 9.98a on which i am testing the moon out on and this is the one that uploads to web page hourly (this was how i spotted it)
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: December 06, 2003, 08:31:37 PM »
i did make a change there
(but its Ok for my soil temperature reading on my extras sensor real time graph)
try:
the setup button on the extra sensor real time graph
and then set the mimium temperature scale for that sensor line
try that
Offline hcorrin
    • Ballaugh Weather
« Reply #2 on: December 06, 2003, 10:37:13 PM »
Sorry to say that had no effect even tried clearing records still no go
Harold
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: December 06, 2003, 10:45:26 PM »
what should it be plotting, and what did you set the minium reading as
email me your wdisplay.ini file, from c:\windows or c:winnt
yes, if it goes out a range, it plots a really high number like over 3000 (although the actual reading was not that high)
Offline hcorrin
    • Ballaugh Weather
« Reply #4 on: December 08, 2003, 07:55:36 PM »
Hi Brian
Have now put 9.98f on main unit and is working ok dispite it clearing records but this was due to reaching its 5000 records limit so im happy on this one.
Many Thanks
Harold
Offline hcorrin
    • Ballaugh Weather
« Reply #5 on: December 09, 2003, 05:22:36 PM »
i have noticed that the record count is not counting on the real time graphs versions F and G beta's, only changes when restarted only tried G otherwise graph seem ok
Harold
