Author Topic: WD crashes under XP after installing 9.97b  (Read 7419 times)
Offline jbeamer
  • Franklinton, NC USA
« Reply #15 on: November 26, 2003, 01:34:15 AM »
Brian,
I'll do that.  Should it be OK if I keep my settings/data from the old install?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #16 on: November 26, 2003, 01:42:23 AM »
yes, try installing back to the old directory,that older win 95/nt version
(which  I am going to update soon)
Offline jbeamer
« Reply #17 on: November 26, 2003, 01:43:50 AM »
Done...I'll let you know how it goes.
John
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #18 on: November 26, 2003, 01:55:20 AM »
what might be happening is some data from the ws2310 wd is not handling very well
what temperature/humidity/barometer?
Offline jbeamer
« Reply #19 on: November 26, 2003, 12:51:52 PM »
Brian, The Win 95 version has been running for 11 hours now with no problem.
To answer your question:
Temp 39.3F
Humidity 81%
Pressure 30.209 in.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #20 on: November 26, 2003, 04:02:20 PM »
good news for you, bad news for me....means i might have upset something in the program.....but, still very few reports....one other on this forum....
now, that its been ok, please try a new 9.97d....
thanks
Offline jbeamer
« Reply #21 on: November 29, 2003, 07:22:10 PM »
Brian,
I have had WD 9.94a running for 3 full days now with no trouble.
What am I missing if I stay at this version?
John
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #22 on: November 29, 2003, 07:30:30 PM »
back that installer up
i.e the file
wdisplay32.exe
put it away somewhere safe
so you can go back to it
latest verison you can plot windchill, and other improvements/fixes
and i want to add a 2nd mesomap soon.
some people have had trouble since 9.97b, which i am trying to find out why, but i think you willbe OK (its been ok for me)
Offline jbeamer
« Reply #23 on: November 29, 2003, 07:39:59 PM »
I'll give it a try and let you know.
Thanks!
Offline Rocketman
  • New Zealand
    • http://tokaanuskihire.co.nz/pukekohe/pukekohe.htm
« Reply #24 on: November 30, 2003, 01:03:59 AM »
I've dropped back to 9.97c ( win 98 ) no more crashing ( generating error dialog box ) .
Now running over 33 hours ( realtime updates and half hourly FTP updates ) .
I'll keep this version going as a test ( seem to be stable ) .
Win98SE/P3/450mhz/384m RAM
V2 Dallas 1-wire WS , barometer ,outdoor humidity ,indoor humidity , raingauge , lighting detector , JJware solar sensor , soil temp sensor , indoor temp, 10 cm soil depth temp , 20 cm soil depth temp , grass temp,leaf sensor
Offline jbeamer
« Reply #25 on: November 30, 2003, 01:42:46 PM »
Brian,
I reloaded 9.97f last night and have two crashes since then.
At this time I reloaded 9.94a which was stable for 3+ days.
John
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #26 on: November 30, 2003, 04:03:51 PM »
9.97g is the latest try at fixing this, there is another thread about this
Offline jbeamer
« Reply #27 on: December 02, 2003, 01:24:16 AM »
Brian,
9.97h has been running for 24+ hours with NO problem.
Thanks for all your hard work in getting the problem fixed.
John
