Three questions - none of which are show-stoppers, more cosmetic.
First - For some reason, this month’s Averages/Extremes page (November2003.htm) isn’t including the links at the end of each day pointing to that day’s 24-hour graph. Is this something that I forgot to turn on? Or is it a bug?
Second - I believe that the syntax for describing the font type (font-family: Arial) in the Averages/Extremes HTML page. is incorrect. I believe that it should be ’ style=“font-family: Arial” '. I mention this only because at the end of each month I go through the page and add some Javascript subroutines, and it’s preventing them from running properly. Obviously easily correctable, but it still takes time.
Third - I have a Davis VP without the Solar/UV sensors. Is the Solar/UV data (which is always 0, obviously) supposed to be displayed on the console screen, even though WD’s configuration is set to no Solar/UV sensors?
