I finally fixed the extre temp/hum data being lost on program restart (i.e if you dont have a datalogger) !
(e.g like under the autoscale graphs, the extra temperature/humidity grpah, the data would get lost
this bug has been there always!!!
I have fixed it, horray!!
version 9.96f
(no its not a joke, its a f for fixed it)
LOL
keep an eye out for it
it should help there too, as with a datalogger, it should fill in the gap…
in theory
anway, i have tested, and its workinig, for me, with my extra sensors, i.,e soil temperature, where before that data was lost…
and , peter, that new vp forecast ticker option in the summary image and icon setup should work now in 9.97
the problem you are seeing at times with that data from the VP download, as we have discussed, and found out, is that the data is not always there in the download data (i.e its a 255 number).
So thats some thing the datalogger does, when the command WD uses is used to get the data history (weather link may use something else)
peter is getting data, joe, but sometimes the extra sensor data like the solar and uv etc is not there in the data (its a 255 value), but the current temperature and other data is
sorry joe, you are still a very much minority when it comes to not get any data extraction at all from the vp data logger
it tis a tough title to bare, but someone has to do it. I wonder if it is something in the logger. Do you suppose after a while the logger gets stale or something?
what i would do, is power down the VP
remove the data logger
then put it back
then power up the VP again
then reset the time/date on the VP
then only use WD for a while, gathering live data,…for a few hours
then exit WD for say 15 minutes *but first check its set to extra data at start up), then restart wd
sorry peter, i am not refering to your extra data from the VP, i am refering to extra temperature/humidity data from any weather station being lost when the program restarts
the fact the data you need is not always in the data from the VP datalogger with the command I use is not my fault…
