cloudy
Author Topic: Getting the wmr100/wmr200 to work  (Read 33789 times)
Offline PeggyD
  • Maple Valley, Washington
Re: Getting the wmr100/wmr200 to work
« Reply #150 on: January 30, 2010, 04:23:32 PM »
I spoke too soon. It worked for a few hours & is now not graphing & the numbers in the display are bizarre. The log files again have static numbers. I'm going to try build 42 & then, if necessary, go back to the old one you posted just a bit earlier in this thread.
I was going to post a screenshot, but I can't get the size down to 128 KB.
« Reply #151 on: January 30, 2010, 06:33:24 PM »
the best way forward is to use the new weathersnoop integration
Dan has that working well now
Offline jmar
  • Halifax, Canada
    • HRM Weather
« Reply #152 on: January 31, 2010, 07:05:53 PM »
To post a screenshot. Double click on the screenshot to open the picture in Preview, Select File> Save as ... in the dialog box select jpeg as the type... adjust the size to about 1/3rd of the max size in the sllder. Quality of the pic will still be fine at that compression rate and you can post up to the max allowed (4) with those settings in most cases.
Hope this helps,
Jmar
iMac, 2 x Mac Mini, Mac OS X 10.6.7, Indigo integration, Web - WDL, Saratoga templates, Lightbox
