Brian, for some reason the max temp is not resetting with the daily reset. Just noticed so not sure how long it has been going on.
take a look when you have a sec…
http://www.theviolas.net/weather
thanks
Chris
thanks
Chris
Just checked mine and it’s working fine. Ver 9.96a here.
Cheers
MikeyM
its ok for me too
does it say reseting the temperature under view, program error log after it has suppsoed to?
people have got so angry about this, i have given up
not sure what could have caused it…I have reduced the number of ftp events because I have moved more things local and generating the files local. Not sure if an ftp event would tie into this.
Here is the error log…
ERROR: I/O error 32 at time/date 6:01:05 PM 11/5/2003
ERROR: I/O error 32 at time/date 6:46:05 PM 11/5/2003
ERROR: I/O error 32 at time/date 7:01:05 PM 11/5/2003
ERROR: I/O error 32 at time/date 8:01:05 PM 11/5/2003
ERROR: I/O error 32 at time/date 8:16:05 PM 11/5/2003
ERROR: I/O error 32 at time/date 8:31:05 PM 11/5/2003
Cannot create file c:\wdisplay\webfiles\forecast5day.gif
Resetting rain daily value , day: 6
Resetting wind/temperature daily value , day: 6
ERROR: I/O error 32 at time/date 1:01:06 AM 11/6/2003
ERROR: I/O error 32 at time/date 1:46:05 AM 11/6/2003
ERROR: I/O error 32 at time/date 5:31:06 AM 11/6/2003
ERROR: I/O error 32 at time/date 7:46:06 AM 11/6/2003
ERROR: I/O error 32 at time/date 2:01:10 PM 11/6/2003
ERROR: I/O error 32 at time/date 2:16:11 PM 11/6/2003
ERROR: I/O error 32 at time/date 4:31:09 PM 11/6/2003
Resetting rain daily value , day: 7
ERROR: I/O error 32 at time/date 4:31:10 AM 11/7/2003
ERROR: I/O error 32 at time/date 8:16:05 AM 11/7/2003
Dont worry…I have patience…I dont get angry too often.
thanks Chris
btw…I will try again tonight and see what happens. I also have some other 1wire temps so I will do a customreport and see if those are resetting also.
it reset here on day 6
but there is no entry for it occuring on day 7, only the rain
i do not know why
note, the temperature now resets at 1 minute past the reset hour
i put a check in at 2 minutes past the reset time hour…now
in a new 9.96a uploading now…
check for the new file time etc…
a few others have the same problem…
hopefully that will fix it
looks to have worked…got two resets this time. i guess two is better than none.
ERROR: I/O error 32 at time/date 10:46:06 PM 11/7/2003
ERROR: I/O error 32 at time/date 11:01:05 PM 11/7/2003
Resetting rain daily value , day: 8
Resetting wind/temperature daily value , day: 8
thanks Brian
Chris
