All Time Records/current month record values
In All Time Records, everything looks OK, but when you click “THIS MONTH”, the two fields for warmest November night temp and the coldest November temperature have disappeared.
NOW - press “back” and you will find that this information has also been cleared in the ALL TIME RECORDS too.
If you go back to view to reenter, you will find ALL TIME RECORDS ok again, but the same will problem will reappear again when you again access THIS MONTH.
Since downloading the latest 9.96a version, the information above on previous postings has changed, but the figures indicted now show on the ALL TIME RECORDS section for that month! Should this be placed in the section for the current month?
