Temperature trend
In the screen shot below notice the temperature comparasion for the “last 24 hours”.
It displays +17.1F even though it is within 5 degrees F of yesterday’s temp at this time. All other data appears to be correct.
I noticed this before just never mentioned it.
I checked November’s .txt log file and it is correct with regards to yesterday’s temperature. I do have a WD temperature offset correction of 2.2F plugged in since my 2310 reads off by that much when above 55F.
John
WIN98SE
WS2310 wired.
WD ver 9.96
Hi Brian, In the screen shot below notice the temperature comparasion for the "last 24 hours". It displays +17.1F even though it is within 5 degrees F of yesterday's temp at this time.
I can't see the time on your "Weather Trends" shot. What does your 48 hour graph indicate as the temperature for the time of the trend shot on the days involved?
i think you will find this is a start of the month problem
should be OK now
I downloaded ver 9.96a yesterday and it appeared to be OK till this morning when I am showing a +16F 24 hr trend from yesterday at this time when it is actually about a -13F difference. We are under the back door cold front over the NE coast so the temps have moderated. Also the trend as compared to last month is now blank for all readings.
The .txt log files look OK for October and November.
I did try converting the txt to graph files for this month and last month and it showed “completed” within a second or 2 after pressing the convert button. That seems real fast to walk through a months worth of data (October) and generate a new inf file.
CaptDilli,
The 72, 48 and 24 hr charts look OK. However the week chart is mostly flat lines as shown below.
John
WIN98SE
AMD XP1500
256 megs RAM
WD ver 9.96a
http://www.jcbagley.com/weather
jbags, do you have a ws2010 daga logger?
as there is a problem there with wd and the trends
Brian,
I’m just using a wired or is it weird :slight_smile: WS2310 with the logger off. I’m at work now but will double check when I get home shortly.
John
The WD hats and stuff on the cafepress.com site looks real good. You need to put a link on your main page.
Brian,
I just checked and the WS2310 data logger is off.
John
ok, your not using a ws2010 data logger, so thats good
wd uses the data from the last 24 hour graph
check that, under view, graph history and see how it looks there
The 24 hr graph from the “view” menu looks good. It displays about 60F yesterday at this time. Right now it is 64F but the 24hr trend is reporting +22F.
However, the realtime graphs (double click from the console) were a mess. It appears that some hours duplicated and others are missing. I should have got a screenshot for you. I cleared the graph history and will let you know what I see after work today.
Maybe a clue :
I recall discussions regarding using the WS2310 clock to adjust the PC clock. I never look at the WS2310 console. It is tucked away behind some books. It may be way off for time/date.
While I am not using the logger is it possible that the time code from the 2310 is adjusting the PC clock ?
I am running a program called NIST Time 32 which adjusts the PC time each hour with an internet time server. I have it running at 10 past the hour so it doesn’t interfere with any WD FTP activities. I have found it to be very accurate. Maybe the wrong time from the 2310 gets input into WD and the NIST program corrects it so I never see the time off on the PC.
Since I appear to be the only user with this problem, let me monitor this for a couple of days and see what happens. Maybe the combination of the change from daylight savings time on Oct 26 and the end of month has WD confused. :slight_smile:
John
there has been a few other reports of this
zip and email me your month112002.inf file from the folder data files
(when the trends are screwy)
The trends are still screwy so I will email the zipped 112003.inf file shortly. Here is what it is showing now and I copied the .inf file at the same time:
according to the monthly .txt file :
yesterday 17:15 11/05 Temp 68.7F Humidity 92% Dew 66.3 Baro 30.029
The uploaded console .gif :
today…17:15 11/06 Temp 60.3F Humidity 100% Dew 60.3 Baro 30.059
Trends reports
today…17:15 trends Temp -2.3F Humidity +54% Dew +19.5 Baro +0.081
The temp and baro are close but humidity and dew pt are way off.
There is nothing showing in the program error log.
Something new I discovered. See below.
Recall that this morning I found the real time graph all out of wack so I reset. At 11:45AM during lunch I took a look at it and it seemed OK. However at about 4:55PM when I again looked, notice the barometer drop at 11:45AM (first viewing) and then the correction at 4:55PM (second viewing). Really strange. I didn’t change anything only clicked OK to exit the screen. I realize I am giving you alot of infomation to analyze so take your time.
John
i found what is wrong with the 24 hour temperature trend
it started when i now dont reset the monthly graph at the start of the month, but keep last months, which is overwritten…
and becuase I was checking for today day in the data, then advancing to same minute and hour, it was actualy finding todays day a month ago…
uploading a new 9.96a now, keep an eye on the file stamp date/time for when its avaialble on the download page (in about 1 hour)
Brian,
Have downloaded the latest 9.96a (11/07 file date). I’ll watch it for the next day or so and see what happens with the trends.
Should I do a convert .txt to .inf files ? My month to date graph starts on Oct 28 or might that be OK after the midnight recalc ?
John
re your month to date graph:
i will check on that…
its ok for me here…
now, this barometer drop out on the real time graph
what was the reading (hpa please, i,.e switch to hpa to see (dont worry you can switch back)), as i may have a problem with the ws2310 code, and i may need to add some debug code so tyou can help me pin point it
Hey Brian,
Good news :
The trends look OK today so 9.96a (11/07) appears to have corrected it.
When I looked at the real time graphs to get the hpa values for you, the barometer plot didn’t drop out as it did yesterday.
The hpa readings at yesterday’s barometer drop out were :
1019.6 just before
949.4 during the drop out
1018.3 just after the drop out
Again all I did was view the real time graph. I didn’t change anything yesterday except press OK when finished.
Here is a screen shot of the graph drop plotted as hpa (I removed the wind direction and values for clarity):
I’ll let you know what the month to date graph looks like after midnight.
John
taadarrr
(re the temperture trend)
:slight_smile:
Brian,
The trends are looking good again. This bug is history.
John
thats good
there are only a few more bugs left…that i know of
the last newsletter I asked for bugs, and only a 1 i have not had a chance to fix yet (and end of month glithc with the graph for the month)
so things are looking good at the monment!
(and the each email feature i need to get working correct too)
Brian,
O dont know if it really is a bug
I use the VP and want to have the forecast text on my PC
ok, i see the problem
to get the vp forecast text to show, the use the forecast has to be set…
but that then stops the solar updating of the icon
i will add option to show the VP forecast ticker, which will mean it will show regardless
