Author Topic: 1 wire UV Sensor  (Read 17815 times)
Offline mikeym
  • Thornhurst, Pa USA
    • MikeyMs Thornhurst,PA Weather
Re: 1 wire UV Sensor
« Reply #15 on: May 20, 2008, 09:29:59 PM »
Hi Mick
I for one would be interested in the 1-wire interface to the Oregon UV sensors. Your work has been great. Reminds me of my tinkerings about 40 or more years ago. Keep up the good work.
Cheers
 :D
MikeyM
http://mikeymsweather.com/
Another VERY Happy WD user
Shuttle XS36v4 8 GB RAM
Davis Vantage Pro 2 wireless w/ Davis solar sensor
Laser Snow Depth Sensor LR4/Fluke 414D working in WD thanks to Brian
Offline MichaelPT
  • Staffordshire Nr Leek
    • Weather-Above
« Reply #16 on: May 25, 2008, 12:08:04 AM »
Hi everybody
I've worked out how to connect the UV sensor to the 1 wire network
as soon as I finished my lightning radar project, I will start testing   sometime next month
mick :)
Offline StokesValleyWeather
  • Stokes Valley, Lower Hutt, New Zealand
    • Stokes Valley Weather
« Reply #17 on: June 01, 2008, 08:42:41 AM »
Hi all,
I am certainly keen on building some sort of 1-Wire UV Sensor from scratch. Am considering purchasing a Oregon UVR 138 as a first step with the possibly converting that to a 1-wire if someone could give me a Circuit Diagram of one.
The other thing I was considering was using (as Mike above) a 1-wire battery monitor DS2438Z and either using the VSense+ input or the VAD depending on the output of UV sensor and the Opamp circuit. Anyone got any preliminary designs that would consider sharing?
I did find the following UV sensor and circuits which is a starting point. http://www.kyosemi.co.jp/product/data/en/KPDU34PS1.html
As I have only basic Electronics knowledge, would anyone consider collaborating with me on this? The only issue I see then would be calibrating it accurately.
Colin, I would be keen to talk to you on the phone to see what you have.
Cheers
Derek C
SV Weather, LH, NZ
Regards
Derek
Stokes Valley Weather,
Lower Hutt, New Zealand.
Offline MichaelPT
    • Weather-Above
« Reply #18 on: June 03, 2008, 11:10:58 PM »
Hi everybody
I am currently working on a instruction sheet how to convert the UV sensor for the Oregon weather station
so people can have a go themselves or find somebody to do for them
I will also add a page with my suggestions for the 1 wire UV sensor
I will also suggest how to calibrate the unit in whether display
I'm hoping to have all the photographs and instructions completed by the end of this month
mick :)
Offline JohnnyBoy
  • Hassocks, West Sussex, UK
    • John's Library
« Reply #19 on: June 04, 2008, 06:36:21 PM »
Hello Mick,
That sounds good, will be watching.
John
Offline MichaelPT
    • Weather-Above
« Reply #20 on: June 05, 2008, 01:06:02 PM »
Hi everybody
I have now completed, some instructions on converting the UV on my webpage for the Oregon weather station
I have also put a link with some information on my idea
to use this with the 1 wire system
mick :)
Offline mikeym
« Reply #21 on: June 05, 2008, 01:35:07 PM »
Hi Mick
Looks like the only sensor available in the USA us the UVR 128. Can I assume the only difference is the wireless freq ??
Thanks for the work on this project.
Cheers
 :D
MikeyM
Offline MichaelPT
    • Weather-Above
« Reply #22 on: June 05, 2008, 02:07:57 PM »
Yes it will be only the frequency the idea is to replace the transmitter
using your extra temperature sensor, or hobby board moisture sensor seems the best bet
to interface with the 1 wire system
mick
Hi Mick
Cheers
 :D
MikeyM
Offline mikeym
« Reply #23 on: June 06, 2008, 12:55:46 AM »
Thanks Mick
 :D
MikeyM
« Reply #24 on: June 06, 2008, 09:33:48 AM »
Hi  MichaelPT,
Can you post the link to your to you info re the 1-wire Solar. Thanks
Regard
Derek Chapman
Lower Hutt, NZ.
Regards
Derek
Offline MichaelPT
    • Weather-Above
« Reply #25 on: June 09, 2008, 06:16:16 PM »
http://www.weather-above.com/uv1%20mod%20introductions.html
Hi  MichaelPT,
Regard
Derek Chapman
Lower Hutt, NZ.
Offline David W
  • Isle of Skye, Scotland
    • 24 Elgol
« Reply #26 on: August 30, 2008, 03:10:31 PM »
A question about the instructions, if I may...
In the text below Fig 3 you write
Quote
I recommend using a screened cableit is important to measure out exactly 27 inches
I'm intrigued to know the significance of the 27 inches.
PS. I just got brave (reckless?) and took the back off a THGR928N (the only awkward bit is that the top pair of battery connectors are attached to the front so, once you have the screws out, you may need to apply a little pressure on those too to ease the case apart). Once apart you can see that the RH and T sensors (right at the bottom of the case) are well off the PCB (right at the top of the case) and connected to the PCB by thin wires. Mmmmm, I wonder that gives scope for a single 'extra' sensor to be the basis for two mods (thus making the most of the limited channels), and if the same arrangement exists in the other 'extra sensors', particularly the OS-THGR810, if that gives scope for 'moded' sensors on the WMR100 & 200 (for which there is not yet a 'probe on a wire' extra sensor)...
PPS. The reassembled THGR928N is working fine.  :)
Regards
David
Offline mikeym
« Reply #27 on: August 30, 2008, 09:38:16 PM »
btw I found out the UVR128 is completely different internally than the UVR138. I took it apart, but haven't had time to see if I can found the output of the sensor circuit to interface to the 1-wire network. If I make any progress I'll post the results.
Cheers
 :D
MikeyM
Offline MichaelPT
    • Weather-Above
« Reply #28 on: August 30, 2008, 10:02:18 PM »
To bring the UV1 in a acceptable range for calibration you need to place a resistor and the cable length gives a very small resistance
which works out really well   and this gave me a standardised measurement
You can use any temperature sensor all you need to do is locate like you have done the thermistor and carefully remove the thermistor  and connect
a screen cable to this then follow the instructions about the UV conversion,
UVR128 is my second choice for the modification have not got round to it yet,
is any chance you could take some close-up pictures of the circuit board and circuitry
mick :)
Offline mikeym
« Reply #29 on: August 31, 2008, 01:50:31 AM »
Hi MIck
I'll try to get some pics of the UVR128 for you tomorrow as it's getting late here tonight.
Cheers
 :D
MikeyM
