Lets say we have a monsoon here in the UK...
If its 999mm per hour max, thats 16.65 tips in a minute (i think maths aint good lol)
if i now divide that by ten then by rights my bucket now should only be able to handle
1.665 tips per minute, is that right? prob not lol
You are nearly there - but change "tips" to "mm".
If 999mm/h (standard) really is a physical limit, then 16.65 is the max tips that the mechanism can handle, and would be a fixed point of reference regardless of how much rain each tip actually represents.
If that is the case, with your 01.mm per tip instead of the standard 1.0mm per tip
your max rate would be 99mm/h (i.e. 10 times higher sensitivity, 10 times lower max rate).
But going back a little while now when we did have some heavy rain, what i noticed was
on the graph, it didnt go up by 0.1mm all the time, there was times when it actually jumped
to say 0.6m or 1.0mm, so i think as its tipping away its storing it in memory then passing it to
WD on the next cycle...
Yes.
If (with your current mod) there has been a 0.6mm step in WD, that was 6 tips - or 10 tips for a 1.0mm step.[/quote]
rain rate, that was january at 228mm/hr that was BM
Before Mod lol
But didn't you have a 0.25 mod before the 0.1mm?
With no mod that would be approx. 16 seconds between tips.
With a 0.25mm mode it would be approx. 4 seconds between tips
And with a 0.1mm mod it would be approx 1.6 seconds between tips.
Oddly my "All Time Records" give a mm/min figure. Maybe the unit is an option somewhere?
My record is 10.0mm/min (back on 23rd Feb this year), and with an unmodified gauge.
That rate is 6 seconds between tips with the unmodified gauge,
equivalent to 1.5 seconds between tips with 4 times (0.25mm) gauge,
or 0.6 seconds between tips with a 10 times (0.1mm) gauge!
I'd be
really impressed if the OS gauge could handle 0.6 seconds between tips!
