cloudy
Author Topic: modify bucket to 0.1mm  (Read 44726 times)
Bashy
  • Guest
« on: February 27, 2008, 09:37:29 AM »
Hi folks
I already have 0.25mm and now i want to go to 0.1mm please
I am ready to go out the door to buy the funnel/bowl but i am
not sure what diameter i need...
Also what offset would i need t0 add for this size please?
Any advice please?
UPDATE:
Derek has kindly made a calculator in MS Excel and can be found in this post further in this thread
Thank you Derek
Niko point me to this tip conversion maths thing, should start here
http://www.realweatherstation.com/rgcalc/
« Last Edit: April 16, 2009, 06:59:10 AM by Bashy »
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
    • Juneau County Weather
Re: modify bucket to 0.1mm
« Reply #1 on: February 27, 2008, 09:52:47 AM »
This kind of thing come up often enough, wouldn't it be nice if someone wrote a little online calculator?  It would take someone better with the math than I am.
- Jim
 Home of NSLog NexStorm Lightning Data Manager
Bashy
  • Guest
« Reply #2 on: February 27, 2008, 10:22:07 AM »
I even tried doing a search for my other posts, can i hell as find it... #-o
Although that didn't actually give me the answer as i settled for the .25 in the end
but yeah a calculator would be a great idea
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
« Reply #3 on: February 27, 2008, 11:04:02 AM »
It is very easy:
original section / new section = resolution
So: new section = orignal section / desired resolution
An example for your particular case:
- Desired resolution = 0.1 mm
- Original Oregon section = 78.5379 cm2
- New section required= 78.5379 / 0.1 = 785.379 cm2
- Section = PI * square radius; Radius = sq root (section / PI)
So you need a funnel of 15.81 cm radius. Or 31.62 cm diameter.
Edit: just a note on this. Take into account that you are letting so much more water inside, so the tipping mechanism can be easily overflown. The accuracy you're looking for may become a big error.
« Last Edit: February 27, 2008, 11:10:36 AM by Breitling »
Bashy
  • Guest
« Reply #4 on: February 27, 2008, 11:10:03 AM »
Easy, yeah i can see that.... :? lol
I do not understand the majority of that, maths is far from my strong point
But i thank you for the answer
Actually, i think i do sort of, in my cause all i needed to do was to move the decimal
so am i right in thinking the offset would be 0.1?
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
« Reply #5 on: February 27, 2008, 11:25:30 AM »
I don't know exactly what you have done. This is what you need:
- Control Panel
   - Offsets & initial rain
      - Rain offset
         - Modified rain gauge new tip (mm)
1.- Calculate the new section: divide funnel diameter by 2. Square it (multiplying by itself). Multiply by 3.1415
2.- Divide the old section (original Oregon) by the new section.
3.- The result is what you have to enter on WD.
Bashy
  • Guest
« Reply #6 on: February 27, 2008, 11:30:26 AM »
Looks like i went the wrong way, it was more of a guess... #-o
So, with the sums done, i make the offset at 10. does that sound more realistic?
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
« Reply #7 on: February 27, 2008, 11:56:22 AM »
No, it is not an offset. It is a new tip volume.
Let me know the inner diameter of your funnel, I'll do the math for you.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #8 on: February 27, 2008, 01:03:50 PM »
Just my personal opinion but I think that's an unreasonable decrease in tip size. I wouldn't be trying to push that amount of water through that coffee mug sized OS rain gauge.
Bashy
  • Guest
« Reply #9 on: February 27, 2008, 01:49:56 PM »
Sorry Breitling  it was the tip size i was on about, its cause its in the rain offsets is why
i kept calling it the offset  :oops:
The internal Diameter is now exactly 31cm thanks Breitling...
i cut the darn thing down too much, so much for the 0.1mm, it cant be too far off though :)
I just want to give it a try Niko, see how it goes, if its too much then i will just remove it
It looks a bit ott i mist admit cause each stage i have made it bigger i just kept the older
one attached so it had the area for the new one to fit into, to its a 3 stage tower now lol
I also had to use a biggish flower container, finding a funnel was proving difficult for the size
wanted, so i went for something much bigger and cut it down...I aint attached it to the bucket
yet so no pics at present sorry, to be honest i dont really want to show it off either  :oops:
Offline MichaelPT
  • Staffordshire Nr Leek
    • Weather-Above
« Reply #10 on: February 27, 2008, 02:34:22 PM »
hi Simon
0.1   is going to give you quite a few problems ,   as soon as you get    moderate  rain  it will  overwhelm the sensor
 and give you  incorrect rain readings
 the lowest I have managed to get 0.25  tipping  so far  this is give me good results   I would have fought there was a standard for the minimum  tipping  of most  rain gauges  Davies  0.2
 I will be interested to see  how you go on with this  please send me some data back  when you have some  heavy rain
I would also put out a  traditional  manual rain gauge  so you can compare  results
mick :)
Bashy
  • Guest
« Reply #11 on: February 27, 2008, 02:46:00 PM »
Its up and waiting for the rain now lol
If it does cause any issues then i will just remove it again, its was stuck down with
hot glue so thinners will easily dissolve the glue, dont care about the addons if they
melt a little i can just sand them down :)
I will certainly let you know how it goes, theres a manual weather station in Lidl later this week
could be now actually, i cant remember and i will get that to compare with :)
I thought davis was 0.1mm? oh well lol but i did read on here somewhere that someone did modify
to 0.1mm and it was running ok, just cant remember where i read it now...
I dont think its gonna be quite 0.1mm anyway as i cut it down too much  #-o
Just need to tip size and im good to go :)
« Last Edit: February 27, 2008, 02:48:11 PM by Bashy »
Offline KevPage
  • One Life - Live It
  • Meppershall
« Reply #12 on: February 27, 2008, 02:48:09 PM »
Good stuff Bashy, let us know how you get on (maybe a test pour with a jug?)
You really are the king of diy!
Bashy
  • Guest
« Reply #13 on: February 27, 2008, 02:51:34 PM »
Thanks lol, you aint seen the image yet, attached below  :oops:
A test pour never works out, i always end up doing too fast
But i will report the findings thats for sure.....
Please dont laff, at least the top looks pretty  :lol:
Looking at it i can see it getting blown off either Friday or Sunday  :? :roll:
Offline niko
  • syzygy
  • Global Moderator
« Reply #14 on: February 27, 2008, 03:54:08 PM »
- Jim
www.realweatherstation.com/rgcalc    :lol:
Maybe better math, but certainly not better php  :oops:
