Weatherlink 5.8-> USBxpress mode
Indeed they seem to offer Silabs USBXpress to skip the UART
http://www.eetindia.co.in/ARTICLES/2007APR/PDF/EEIOL_2007APR27_NETD_AN_01.pdf?SOURCES=DOWNLOAD may be of interest and perhaps Softx could use this with an alternate version of VVP if it chats to the device any better?
I see the install also installs a folder with V5.0 of the standard USB drivers
Automan.
My serial logger and 5.8 work fine.
I think that’s what Davis did in WL 5.8, and apparently the experience is not so good. There is also a person on another forum with the USB connection drop problem who tried WL 5.8 in USB mode, and although the connection problem didn’t occur as frequently, it still occurred. The way VirtualVP works around the VP USB problem has completely solved the issue for many people. I know this because they’ve written and told me. I think I will stick with the current method since it’s proved successful in almost all cases.
Steve
If this USB problem happens with all new USB VP2 interfaces uses who wish to move away from the provided Weatherlink to an alternate product could have an issue.
e.g. Someone buys a VP2, USB Logger and runs weatherlink 5.8 selecting USB.
Weeks later they note Weatherlink is a bit limited in what it does and want to try WD but cannot because no COM port is available.
Automan.
I talked to Larry in support at Davis and he said several people have had this problem and they are working on a fix and hope to have it soon. I don’t know how long soon is, so I ask them to swap my logger so I can get it going again. They are sending me a logger.
There is now a v2 of the utility to convert back to serial port operation, which should have the bug fixed. It should be uploaded to the Davis site in the next day or two.
That is exactly what happened to me. I have had my station up for a week. I setup my web page with Weatherlink last night and thought ‘this is ugly’. Found WD and thought that looks nice and has more options. Went to try the trial version and I can not get it to communicate since there is no Com port. I have been everywhere (boards) trying to figure this out. I am so glad I found this post. I was starting to think I was loosing it. I am not sure how to proceed though. With the new software Davis will not be assigning a com port to the usb anymore? So will WD create a fix or is the only way to downgrade the Weatherlink software?
Another item you may wish to beware of with WL 5.8 is if you are running Vista.
It will install itself under C:\Program Files\Weatherlink and apparently create a folder under Weatherlink containing your station data.
Of course it is not, and Vista just pretends that’s the location of your data so when you try and backup that area under program files your data is not actually saved.
Your data will actually be stored under “C:\Users%username%\AppData\Local\VirtualStore\Program Files\WeatherLink”
If you paste the above line including quotes into the start menu “Start Search” box it should take you to the folder.
Automan.
Gtstricky I would call Davis support and see if they have a fix. The problem is the Davis USB logger gets changed when to choose USB. They were working on a fix. The program that changes the logger back to serial with com ports does not work. I ask to swap data logger and they did (USB) I removed 5.8 and installed 5.7 every thing is working OK. Joe
I see that the updated utility to reset the USB logger for compatibility with the virtual COM port driver is now posted on the Davis site at:
http://www.davisnet.com/support/weather/software_driver.asp
This particular bug is hopefully now squashed.
thats good news
re the vista thing, make sure to run weatherlink as administrator…
I am completely confused, just upgraded from LA CROSSE to VANTAGEPRO2 and trying to resume the WD & WDL.
My weatherlink is USB, it works fine with the Davis 5.80 program (comport defined as USB), what shall I do in the WD Comport number setup (how can I know what Comport number has windows assigned ?) Can someone explain it to me as I got lost with the advices in the forum, is there a simple and step by step solution ?
shall I try it with the 5.7.1 version ? please…
[email protected]
Go to Davis web site and down load progran to change logger back to serial. Then when you set up 5.8 pick serial and you will get com ports. Do not pick USB.
There is an update to 5.8.1 available on the davis site .
visited with Raymond… Weatherlink doesn’t work with 64 bit Vista systems and they don’t predict in the near future a program change. However… Weather Display works just fine.
Is there any one out there using:
DAVIS ENVOY with a IP DATA LOGGER and Weather Display
I am trying but WD on my PC seems to lock up my Davis Data logger on my LAN
Harvey
we got the lock up sorted (it was due to a HTTP clientraw set to download in the client/server setup)
Davis has v2 on their site for download, place in program files/weather display and run it. it changes to serial. After days of hunting and trying we finally got it from usbExpress to serial. Works like a charm.
note that is also a FAQ detailnig how to unset the USBExpress mode
I upgraded to 5.8.3 this morning. there are no new items and it doesn’t improve or detract from 5.8.2 or help vista. the only thing I could see is some minor fixes for things I don’t have …yet and the ability to do something with the wind calibration… WD has done this for a very long time.
At best, on a 64 bit system, it splits up the program, putting some in the program files, some in the virtualstore ( you have to hunt there for your datafiles).
At best it isn’t the best and I really have issue with it costing so much for it and the logger, and they don’t have it more compatible with vista and all of the reports you have to go hunt.
However, it does present the data different ways for me and now that I can use Virtual VP, I get the best of both programs. I think WL is for the novice and WD is still the best out there.
