cloudy
Author Topic: WMR-968, 928, 918 battery level reading  (Read 1151 times)
Offline Ozgur
  • Istanbul / Türkiye
« on: December 25, 2007, 09:50:38 AM »
Hi everyone,
I have a Radioshack 63-1016 wireless weather station, which is identical to the WMR 918-928-968 model stations. As I started to get lower battery level readings in WD for my temperature/humidity sensor sometimes (%50-60 at colder temperatures, e.g. below 7-8 Degrees Centigrade, whereas %100 again when it is warmer) I decided to replace the lithium batteries and also the alkaline backup batteries. However, nothing has changed, the same is still continuing to happen. By the way, I do not get any warning or low battery power indication on the weather station itself.
Is this normal or is the solar cell maybe not being able to collect enough sunshine? It is located in my balcony, so direct sunlight is not available most of the time..
Ozgur
Offline ThorntonWeather
  • Tony
  • Commercial
  • Thornton, CO USA
    • ThorntonWeather.com
Re: WMR-968, 928, 918 battery level reading
« Reply #1 on: December 25, 2007, 12:22:34 PM »
Alkaline batteries have pretty poor cold weather performance.  I believe I have seen on here where most folks recommend replacing them with lithium.  Energizer's specifications for their lithium AA batteries say they have an operating range of -40°C to 85°C.  Of course they are more expensive but might be worth it if there is a concern that your sensors will quit working.
    Tony
Bashy
  • Guest
« Reply #2 on: December 25, 2007, 12:41:43 PM »
I have replaced all mine with Ultimate Lithium batteries, Before i was getting fluctuations in the
batteries but since the change not had one :)
Offline Ozgur
« Reply #3 on: December 25, 2007, 12:54:41 PM »
Bashy do you mean that you have changed the BACKUP batteries, so not the ones being recharged with solar energy, am I right?
Are now your lithium backup batteries disposable ones or are they also rechargeable? Does this specification make any difference?
Ozgur
Bashy
  • Guest
« Reply #4 on: December 25, 2007, 02:02:14 PM »
Yes m8 just the backups
Offline Ozgur
« Reply #5 on: December 25, 2007, 02:03:41 PM »
Rechargable or disposable?
Bashy
  • Guest
« Reply #6 on: December 25, 2007, 02:06:30 PM »
Disposable m8 i aint sure if they do lithium rechargeables?
http://www.ebuyer.com/product/130869
Offline Kojack
  • North Gosforth Newcastle upon Tyne
    • North Gosforth Weather
« Reply #7 on: December 25, 2007, 08:55:08 PM »
Oregon recommend Lithium batteries if you are operating below 0oC.
They also stress that your bacup cells shoud not be rechargeable cells
John
XP Pro SP3
Offline Ozgur
« Reply #8 on: December 26, 2007, 06:05:22 AM »
Thanks Kojack, that is now a very clear and also helpful clue for me! I will act accordingly..
I wish all a Happy New Year!
Cheers,
Ozgur
