Author Topic: PHP Extraction of WD Avg/Ext HTM Files  (Read 43063 times)
Offline MCHALLIS
  • Long Beach, WA USA
Re: PHP Extraction of WD Avg/Ext HTM Files
« Reply #135 on: March 16, 2008, 07:46:25 PM »
Hi Mike
Thanks for your reply.
Im not sure where you set the table-row-dark and light - do you specify that in Kevins avgextract.php?
Henrik
table-top, column-light, and column-dark. are part of the CSS files included with the
Weather Display/PHP/AJAX Website Template Set
http://saratoga-weather.org/template/ for which include-wxhistory.php was adapted for
Offline jwwd
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
« Reply #136 on: March 17, 2008, 11:10:48 AM »
Hi Mike
Ohh now I understand - I have modified my report page and its working great. And im using my css file.
http://www.buskelundtoften.dk/vejret/english/rapporter.php
Thank you very much for all your help.
Henrik
Offline MCHALLIS
« Reply #137 on: April 05, 2008, 02:58:59 PM »
I have attached an updated AvgExtract.php file.
This version supports WD V10.37j+
Since Brian did the rewrite of the Avg/Ext in WD V10.37j+, this file had to be updated.
My fixes are backward compatible with the reports generated with the earlier version.
Rename it from AvgExtract.php.txt to AvgExtract.php then upload it to your server to replace the current AvgExtract.php
Edit: see my later post from 04/06/08 for the download
« Last Edit: April 06, 2008, 02:11:08 PM by MCHALLIS »
Offline jwwd
« Reply #138 on: April 05, 2008, 03:25:03 PM »
Hi Mike
What are the changes you have made?
I run a modified script because my wd files are in Danish.
Henrik
Offline MCHALLIS
« Reply #139 on: April 05, 2008, 04:20:08 PM »
Hi Mike
Henrik
If you look in the file, I commented all the changes with
# mchallis 04/04/08
Offline jwwd
« Reply #140 on: April 05, 2008, 05:19:44 PM »
Hi again Mike
Thanks - didnt see that  :oops:
I have noticed for a while that the graph of the last day always is the day before the last day - ie. if you click the graphs for day 4 of April - you see the graph from April 3rd.
Same thing with all the monhts.
http://www.buskelundtoften.dk/vejret/english/rapporter.php?report=200804&size=1
What can be the problem?
Henrik
Offline MCHALLIS
« Reply #141 on: April 05, 2008, 05:42:34 PM »
Hi again Mike
Henrik
I would have to see the code from your AvgExtract.php file because I think the problem is in it.
Probably caused something you changed because my site does not have that problem
http://www.carmosaic.com/weather/monthly-stats.php
Offline jwwd
« Reply #142 on: April 05, 2008, 06:00:27 PM »
Hi Mike
Would you have a look at my script?
Its attached as a .txt file. (My English version)
Your help is very much appreciated.
Henrik
Offline n9mfk9
  • Springfield IL, USA
« Reply #143 on: April 05, 2008, 06:19:22 PM »
Hi Mike i'm have the same problem
i am use the script as it was posted here
http://98.215.242.116:8080/wx11.php
thanks Beau
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
« Reply #144 on: April 05, 2008, 06:40:07 PM »
I'd kind of hold off a lot of script changes until the changes to the new output file is finished.
There are still some issues with the update that I assume Brian is going to address and when he does, the format of the output page may change further.
There still are some very basic HTML tags missing and in the wrong order that could make parsing an issue.
In a way, it would be nice if the output was simply a plain text file (April2008.txt) with no HTML in it at all.  It would make parsing it a lot easier and then the user can format the output the way they want to using their own style settings.
« Last Edit: April 05, 2008, 06:42:10 PM by TNETWeather »
Offline MCHALLIS
« Reply #145 on: April 05, 2008, 06:48:01 PM »
Hi Mike
Henrik
Henrik,
here is a possible fix for your file, i also added in the compatibility changes you need for the latest WD.
Kevin is correct, more changes in WD might break something, but for now, try this.
Edit: removed the attachment because it was a special version just for Henrik and he already downloaded it.
« Last Edit: April 06, 2008, 02:12:31 PM by MCHALLIS »
Offline jwwd
« Reply #146 on: April 05, 2008, 07:03:51 PM »
Hi Mike and Kevin
I agree with you - lets not make any more changes to the script until Brian has finished the changes to the av/ext reports.
But - I just installed your (Mike) attached scripts and its working real fine now - both in Danish and English
Thank you very much for your help.
Henrik
Offline MCHALLIS
« Reply #147 on: April 06, 2008, 02:09:57 PM »
One more small fix for Maximum humidity on the daily reports, the problem was the word humidity was showing up on the side where the values are.
I only changed one line
array('Maximum humidity',4), # mchallis 04/06/08 (WD 10.37j-01 fix) changed 3 to 4
#edit, I removed the attachment, see later post for latest AvgExtract.php attachment
« Last Edit: April 08, 2008, 02:54:30 PM by MCHALLIS »
Offline jwwd
« Reply #148 on: April 06, 2008, 02:34:14 PM »
Hi Mike
Thanks for the update - havent noticed yet.
Its working perfect.
Henrik
Offline MCHALLIS
« Reply #149 on: April 08, 2008, 02:53:23 PM »
I updated AvgExtract.php to version 1.03
# mchallis Version 1.03 04/08/08 Added support for rain totals in mm
In AvgExtract.php I replaced
Code: [Select]
$level2 = array(
            array(',ET', 2),
            array('Sunshine hours month to date',6),
            array('Sunshine hours year to date',6),
            array('in. on day',0),
            array('in.  on day',0), # mchallis added 04/04/08 (WD 10.37j-01 fix)
with
Code: [Select]
$level2 = array(
            array(',ET', 2),
            array('mm on day',0),  # mchallis added 04/08/08 support for rain in mm
            array('mm  on day',0), # mchallis added 04/08/08 support for rain in mm (WD 10.37j + fix)
It will automatically print the correct rain totals no matter if you use inches or mm for rain.
