cloudy
Author Topic: PHP Extraction of WD Avg/Ext HTM Files  (Read 43057 times)
Offline jwwd
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
Re: PHP Extraction of WD Avg/Ext HTM Files
« Reply #150 on: April 10, 2008, 03:54:04 AM »
I have notised that my:
Day, Sunshine hours, ET, max solar, max uv
are presented 2 times a day like this:
01 05.0hrs  ET :1.4 mm  694.0 W/M²
02 00.6hrs  ET :0.9 mm  700.0 W/M²
03 02.3hrs  ET :1.2 mm  711.0 W/M²
04 00.2hrs  ET :0.9 mm  316.1 W/M²
05 08.0hrs  ET :2.5 mm  727.0 W/M²
06 04.6hrs  ET :2.0 mm  735.0 W/M²
07 06.6hrs  ET :1.8 mm  742.0 W/M²
08 00.1hrs  ET :1.5 mm  545.2 W/M²
09 05.4hrs  ET :1.9 mm  758.0 W/M²
See example here:
http://www.buskelundtoften.dk/vejret/english/rapporter.php?report=200804&size=1
The original April2008.htm file from WD shows the values correct. (www.buskelundtoften.dk/vejret/vejrdata/April2008.htm)
What can be the problem?
Henrik
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #151 on: April 10, 2008, 04:26:15 AM »
I have noticed that my:
Henrik
Please attach your AvgExtract.php.txt and I will take a look in the morning.
Offline jwwd
« Reply #152 on: April 10, 2008, 04:38:47 AM »
Hi Mike
Thanks - avgextract.php.txt attached.
Henrik
Offline MCHALLIS
« Reply #153 on: April 10, 2008, 02:58:17 PM »
Hi Mike
Henrik
Change:
Code: [Select]
$level2 = array(
            array(",ET", 2),
            array("Sunshine hours month to date",6),
            array("Sunshine hours year to date",6),
            array(" mm ",0),
To:
Code: [Select]
$level2 = array(
            array(",ET", 2),
            array('mm on day',0),   # mchallis added 04/08/08 support for rain in mm
            array('mm  on day',0),  # mchallis added 04/08/08 support for rain in mm (WD 10.37j + fix)
The array(" mm ",0), must be something you added, it was interfering with the rain total "mm"
Offline jwwd
« Reply #154 on: April 10, 2008, 03:19:48 PM »
Hi Mike
Thanks for your help (again)
Its working but now my rain totals are missing  :(
Henrik
Offline MCHALLIS
« Reply #155 on: April 10, 2008, 03:27:52 PM »
Hi Mike
Henrik
Try this then
Code: [Select]
$level2 = array(
            array(",ET", 2),
            array('mm 1',0),
            array('mm 2',0),
            array('mm 3',0),
            array('mm 4',0),
            array('mm 5',0),
            array('mm 6',0),
            array('mm 7',0),
            array('mm 8',0),
            array('mm 9',0),
Offline jwwd
« Reply #156 on: April 10, 2008, 03:54:22 PM »
Hi again Mike
Wow you are fast!
One more problem now (I think the problem have been there before the changes) - when I choose another month its always April 2008 which is presented.
What might be the problem?
Henrik
Offline jwwd
« Reply #157 on: April 10, 2008, 04:05:57 PM »
Here is my forms page attached - could the problem be there?
Henrik
Offline MCHALLIS
« Reply #158 on: April 10, 2008, 04:15:42 PM »
Hi again Mike
Wow you are fast!
Henrik
Try this diagnostic version, it will print the date it gets from your form input so I can see if the problem comes from there or not.
I added this, you can take it out or comment it out later.
Code: [Select]
    # test print diagnostic info
    echo "<p>date_to_process: $date_to_process<br />";
    echo 'Month File: ' . $mnthname[$monthnum -1 ] . $yearnum . '.htm</p>';
Offline jwwd
« Reply #159 on: April 10, 2008, 04:32:18 PM »
Hi again
Ok - seems that April2008.htm always is presented:
http://www.buskelundtoften.dk/vejret/english/rapporter.php?report=200801&size=1
Henrik
Offline MCHALLIS
« Reply #160 on: April 10, 2008, 04:34:53 PM »
Hi again
Henrik
The problem is somewhere in your rapporter.php form date selection code
Offline MCHALLIS
« Reply #161 on: April 10, 2008, 04:47:03 PM »
you have
Code: [Select]
$breport = "scripts/rapporter/dagligrapporter.php?date=$date&lt;";
try this:
Code: [Select]
$breport = "scripts/rapporter/dagligrapporter.php?date=$date";
Offline jwwd
« Reply #162 on: April 10, 2008, 04:50:25 PM »
Hi Mike
Its working now - thank you very much - amazing you can point out the errors so fast.
Have a nice day
Henrik
Offline jwwd
« Reply #163 on: April 10, 2008, 07:56:22 PM »
Hi Mike
Thanks for your PM
Hi Mike
Its working - but unfortunately my "Månedsrapport:" and "Årsrapport: " dont work anymore - please see this link:
www.buskelundtoften.dk/vejret/rapporter.php
I have attached rapporter.php.txt - hope you might figure out what is wrong.
Thank you very much
Henrik
Offline MCHALLIS
« Reply #164 on: April 10, 2008, 08:08:23 PM »
Hi Mike
Thanks for your PM
Hi Mike
Thank you very much
Henrik
when I click on "Årsrapport:" it tries to load this page in the iframe:
http://www.buskelundtoften.dk/vejrdata/200804.html
What is it supposed to do? I am not sure what is wrong with the url because I do not know the data structure
