What do you think of this?
http://www.carmosaic.com/weather/monthly-stats.phpTry out the toggle 24 Hour Chart daily image feature (the image links are at the bottom of each daily table)
I have modified and repackaged AvgExtract.php into include-wxhistory.php
I am sending two files (wxhistory.php and include-wxhistory.php) to Ken to be used as a plugin for use in
the Weather Display/PHP/AJAX Website Template Set
Features / Changes:
Modified for style compatibility with my css theme switcher and to be used
inside of a wxhistory.php page in a Weather Display/PHP/AJAX Website Template set
Added if is_file check and toggle image feature for 24 hour chart images
also added other minor formatting changes like
This version of AvgExtract.php I have developed into include-wxhistory.php
At this time, is only designed to be used as a plugin for use in
the Weather Display/PHP/AJAX Website Template Set because it has css style changes inside include-wxhistory.php.
include-wxhistory.php should not be used outside of the Weather Display/PHP/AJAX Website Template Set or it will not work right.
