cloudy
Author Topic: Carterlake Plugin Page - Printable Weather Flyer  (Read 31321 times)
Offline Stronghurst
  • You Are Never Alone With a Schizoid
  • Stronghurst,IL USA
    • Burgus Computers
Re: Carterlake Plugin Page - Printable Weather Flyer
« Reply #30 on: February 08, 2009, 09:32:17 PM »
I get this when I use the script.  http://www.burgus.org/wxflier.php
Quote
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 29
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 29
Warning: Cannot modify header information - headers already sent by (output started at /homepages/26/d195194739/htdocs/Burgus/wxflyer.php:6) in /homepages/26/d195194739/htdocs/Burgus/include-style-switcher.php on line 359
Any ideas?
Mark
Every day is a good day.  Just that some days are better than others.
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #31 on: February 08, 2009, 11:57:59 PM »
Mark, this will fix it. I made a change in the first 18 lines. (Settings.php include had to be first)
Version: 1.02 - 08-Feb-2009
- fixed header already sent error when selecting a style
- fixed missing echo for $reports_from
Offline M. Hebert
  • Saint-Alphonse-Rodriguez, Quebec
    • Météo Lanaudière
« Reply #32 on: February 09, 2009, 01:54:34 AM »
Mike,
Are you going to make available as a download version 1.02?
Offline MCHALLIS
« Reply #33 on: February 09, 2009, 01:57:49 AM »
Mike,
Sorry, here it is:
www.642weather.com/weather/scripts/wxflyer.zip
Offline M. Hebert
    • Météo Lanaudière
« Reply #34 on: February 09, 2009, 02:13:28 AM »
Thanks Mike.  Now to see if I can integrate that to my site and translate to French like I did for the image captcha you made available.
Offline M. Hebert
    • Météo Lanaudière
« Reply #35 on: February 09, 2009, 02:27:29 AM »
Hi Mike,
After a quick look at it, EC has the French text for the forecast in text format so I think I will be able to do something with it.
Offline Stronghurst
    • Burgus Computers
« Reply #36 on: February 09, 2009, 05:18:38 PM »
Is this what you normaly get with the weather discussion  :)
Quote
08z msas sfc analysis places high pressure over the oh vly. Warm front extends near the i-70 corridor across mo with 20+ degree temp gradient across the frontal zone. Strong southerly 40-50 kt winds in h925-h85 layer drawing gulf moisture rapidly north with sfc dewpts in the 50s as far north as central ks through southern mo with 60s from ok and tx into la. Water vapor shows vigorous negative tilt shortwave ejecting from the great basin through the rockies. Zone of strong upper diffluence and positive vorticity advection in combination with dry slot impinging on gulf moisture fueling fine line of convection from south central ks through central tx. Addition elevated bands of convection were forming out ahead from plains into upper midwest ... This discussion continues at www.burgus.org
Mark
Offline BfdWx
  • Branford Connecticut
    • Branford Weather
« Reply #37 on: February 09, 2009, 05:24:07 PM »
Quote
Hey Mark, yes that looks about right. There is a forecast discussion script that you can setup as a separate page. Look on my front page, then click on "the discussion is continued here" towards the bottom of my page.
Jack
Offline Stronghurst
    • Burgus Computers
« Reply #38 on: February 09, 2009, 05:33:42 PM »
I can just see the local little old ladies seeing this and wounder what language it was :)
Is that one of the available scripts that you used to create that discussion page.  Look great.
Mark
« Last Edit: February 09, 2009, 05:35:23 PM by Burgus »
Offline BfdWx
    • Branford Weather
« Reply #39 on: February 09, 2009, 08:36:23 PM »
Quote
It sure is....http://saratoga-weather.org/scripts-NWSmisc.php#NWSAFD, just another one of Ken's great scripts!!
Jack
Offline Koolkid1935
  • Powell, WY
    • Powell Wyoming Weather
« Reply #40 on: April 11, 2009, 02:15:01 PM »
Is there a way for me to adapt the weather flyer script to use with VWS?
Offline Stronghurst
    • Burgus Computers
« Reply #41 on: April 11, 2009, 03:15:05 PM »
Does VWS create a file on your server that has the information you want in the flyer?
Mark
Offline Koolkid1935
  • Powell, WY
« Reply #42 on: April 11, 2009, 05:26:09 PM »
Yes it does.  It looks like all I need to do is replace the values that WD uses with the equivalent VWS value and run it through VWS.  I am hoping that will work anyways.
Offline Stronghurst
    • Burgus Computers
« Reply #43 on: April 11, 2009, 07:13:46 PM »
I know several of the coders here write scripts for both programs.
Mark
abaldish
  • Guest
« Reply #44 on: April 11, 2009, 09:34:29 PM »
Another great script, Never knew it was out there till i seen the thread. So it is added here as well!
