cloudy
Author Topic: Carterlake Plugin Page - Printable Weather Flyer  (Read 32313 times)
Offline edje1205
  • edje
  • Zaandam Holland, the Netherlands
    • http://www.weersverwachtingen.eu
Re: Carterlake Plugin Page - Printable Weather Flyer
« Reply #150 on: January 23, 2010, 01:01:46 PM »
Seen this ?
http://www.weersverwachtingen.eu/clientraw/wd-ajax-ml/wxflyer-wxsim7.php
Not working on IE7  #-o
any additions in this script needed for it ?
Code: [Select]
<script type="text/javascript" src="http://www.google.com/jsapi?key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"></script>
<script type="text/javascript" src="gfeedfetcher.js"></script>
<script type="text/javascript" src="gajaxscroller.js">
* gAjax RSS Pausing Scroller- (c) Dynamic Drive (www.dynamicdrive.com)
* Requires "gfeedfetcher.js" class
* This notice MUST stay intact for legal use
* Visit http://www.dynamicdrive.com/ for full source code
</script>
<div style="width:450px; margin:0 auto; text-align:left;">
<style type="text/css">
.titlefield{ /*CSS for RSS title link in general*/
text-decoration: none;
.labelfield{ /*CSS for label field in general*/
color:brown;
font-size: 90%;
.datefield{ /*CSS for date field in general*/
color:gray;
font-size: 90%;
#example3{ /*Demo 3 main container*/
width: 450px;
height: 165px;
border: 1px solid navy;
padding: 4px;
background-color: lightyellow;
#example3 div p{ /*Demo 3 P element that separates each entry*/
margin-top: 0;
margin-bottom: 7px;
code{ /*CSS for insructions*/
color: red;
</style>
<h3><center>knmi & weeronline</center></h3>
<script type="text/javascript">
var newsfeed=new gfeedpausescroller("example3", "example3class", 5000, "_new")
newsfeed.addFeed("knmi", "http://www.knmi.nl/rssfeeds/knmi-rsswaarschuwingen.cgi") //Specify "label" plus URL to RSS feed
newsfeed.addFeed("weeronline", "http://rss.weeronline.nl/weernieuws.xml") //Specify "label" plus URL to RSS feed
newsfeed.displayoptions("datetime snippet") //show the specified additional fields
newsfeed.setentrycontainer("p") //Display each entry as a paragraph
newsfeed.filterfeed(8, "date") //Show 8 entries, sort by date
newsfeed.entries_per_page(2)
newsfeed.init() //Always call this last
</script>
Ed
Woodenshoes,mills,hightech;but random weather
P4 2,2Ghz-2GB RAM-Win2K-Broadb.connect
Offline i_fiorentino
  • Alessandro Bardi
  • 160 mls Carmignano (Po), Tuscany, Italy
    • Meteocarmignano.it
« Reply #151 on: January 24, 2010, 11:11:32 AM »
the printable weather flyer doesn't have any graphic banner.
My problem should be in the css file but i don't know how to fix it.
Any help please?
Link: http://www.meteocarmignano.it/wxflyer.php
Many thanks,
Alessandro
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
« Reply #152 on: January 27, 2010, 10:56:07 PM »
Getting an error on my Flyer page all of a sudden. Been using it for a few months without any problems at all...This is the error..
Fatal error: Call to undefined function curl_fetch_file() in /virtual/users/e16108-17165/web/wxflyer.php on line 394
 $Status .= "<!-- Warning: forecast-discussion cache file size = " . strlen($xml) . " is too small.. fetched data not found. -->\n";
     $Status .= "<!-- forecast-discussion Cache file HTML contents: " . htmlspecialchars(strip_tags(str_replace('-->','',trim($xml)))) . " -->\n";
     $get_file_failed = 1;   <<<<<< Line 394
By the looks of it, its a cache problem. I've deleted the nws-forecast-discussion.txt file and made a new one and set it to 666, but the problem is still there. Ive also tried to Force an update, but that didnt do anything. Any Ideas? Thanks, Mark.
http://www.snoqualmieweather.com/wxflyer.php
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #153 on: January 28, 2010, 05:40:13 PM »
Mark, what version is your wxflyer.php?
the latest version is Version: 1.12 - 06-Nov-2009
If you have an older version that could be the cause.
Mike
  • Mark
  • Snoqualmie,WA
« Reply #154 on: January 28, 2010, 09:25:54 PM »
I downloaded a new file from your site lastnight, So it must be something else causing this issue.
Offline MCHALLIS
« Reply #155 on: January 29, 2010, 12:47:45 AM »
It is because you changed the alert box to the AtomFeed
The curl_fetch_file function is normally included in the atom-advisory.php that you removed. It is needed for the forecast discussion.
You could try extracting that function and adding it to the wxflyer.php
Offline drobbins
  • Kentucky, USA
    • Cave Country Weather
« Reply #156 on: January 29, 2010, 02:35:24 AM »
Is this normal for the discussion? (note spelling, time format and capitalization)
http://www.cavecountryweather.com/wxflyer.php
Quote
After coordination with neighboring offices and hpc...will issue a winter storm warning for about the srn 1/3 of our fa with winter wx advisories to the north for friday. The heaviest snowfall totals shud be near the tn line. Warnings in the south will begin at 12z-15z with advisories in the north from 18z-21z. Warnings/advisories will run thru 21z sat. Light snow shud first develop into our swrn most fa around 12z fri with a steady push ewd but only gradual push northward with drier air in the low levels encountered. Upper level low/trof now lifting ene acrs the srn rockies/srn plains will approach sat as an open positive tilt trof. Associated sfc low pres/inverted trof will be pointed primarily at the lower ms vly early fri...shifting ... This discussion continues at www.CaveCountryWeather.com
« Last Edit: January 29, 2010, 02:52:17 AM by drobbins »
Offline MCHALLIS
Offline drobbins
  • Kentucky, USA
« Reply #158 on: January 29, 2010, 11:17:15 AM »
I guess I should have checked that. Do you know of a better source?
Offline drobbins
  • Kentucky, USA
« Reply #159 on: January 30, 2010, 03:19:27 AM »
Looks like they use the vitameatavegamin before they type
http://www.google.com/search?hl=en&q=vitameatavegamin
:lol: I finally got a chance to look that up.  :lol:
The discussion has been changed to two more forecasts.
  • Alessandro Bardi
« Reply #160 on: January 30, 2010, 01:20:04 PM »
Any help please?
Many thanks,
Alessandro
Hi guys,
how about my header issue?
Can anyone help me please?
Many thanks,
Alessandro
Offline MCHALLIS
« Reply #161 on: January 30, 2010, 08:45:39 PM »
Hi guys,
Many thanks,
Alessandro
Because it is a printable page, it is supposed to show your web site URL at the top.
Like here:
http://www.642weather.com/weather/local-flier.php
Yours is not even doing that.
Your page has many validation errors. I would start there.
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.meteocarmignano.it%2Fwxflyer.php
  • Alessandro Bardi
« Reply #162 on: January 31, 2010, 05:59:13 AM »
Hi Mike,
i've corrected some errors but it remains 11 that i don't know hot to fix it.
But the problem persists.
Could you give me the source code of your page?
Many thanks for your help,
Alessandro
Offline Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
« Reply #163 on: January 31, 2010, 08:04:51 AM »
All those errors are from the Print button that you've added in this part of the page:
Code: [Select]
function stampa(){
if (window.print) {
    window.print() ;
} else {
    var WebBrowser = '<object id="WebBrowser1" width=0 height=0 classid="clsid:8856F961-340A-11D0-A96B-00C04FD705A2"></object>';
document.body.insertAdjacentHTML('beforeEnd', WebBrowser);
    WebBrowser1.ExecWB(6, 2);
</script>
var NS = (navigator.appName == "Netscape");
var VERSION = parseInt(navigator.appVersion);
if (VERSION > 3) {
    document.write('<form><input type=button value="Stampa questa pagina" name="Print" onclick="stampa()"></form>');
</script>
Try removing that code and see if the header will display correctly and the page will validate.
The header title is there, it's just hidden behind the menu and the main page area.  :wink:
  • Alessandro Bardi
« Reply #164 on: January 31, 2010, 02:52:18 PM »
Hi Martin,
now the page is validated but the header doesn't still show correctly.
And how about the print button?
Many thanks,
Alessandro
« Last Edit: January 31, 2010, 02:54:30 PM by i_fiorentino »
