update , new wmr100/200.exe program to use:
http://www.weather-display.com/downloadfiles/wmr100.zip
(vers 2.8 of that), unzip to where you have WD installed
(and exit the current running version first)
and then have the sensor number for outdoor temp/hum to use in the weather station type setup or under view, wmr968/wmr100/200 extra data set to 0 (default)
and bingo, the outdoor temp/hum data should be updating every minute or so
I will update a new full version with this fix now too
(and the free basic version)
I apologise for the problems and frustations this has caused everyone
(the problem was the data was being appended on the end of other data and it was then being missed)
:oops: #-o
The free basic version of WD for the WMR200 update is available from here:
http://www.weather-display.com/downloadfiles/wdisplaybasicwmr200.exe
(do not use if you have purchased and registered weather display)
