Hi Henrik
I'm really glad it's working
In common_en.php, translate the values in
$db_fieldname = array and
$month = array and
the text under //Translate this ('Compare ' and ' with ') keep the blank space.
under //linecolor and labels for data-select, translate 'line ' and 'Not selected'.
You can add more values in the select droplist, copy them from
$db_field = array like this: 63 => "heat_index", and translate/rearrange them.
In multiwx_en you can translate text between ><, like >Select time/date< to >Välj tid/datum<
You can copy the form to another page, just make sure to set the paths for
include '../multiwx/common_en.php';
src="../multiwx/setradio.js">
src="../multiwx/showhide.js">
href="../multiwx/multi.css" /> (You can copy the content to your regular css-file and skip this one, just remove the top section)
<img src="../multiwx/multigraph.php" alt="Graph" title="Weathergraph" />
right.
Your server is slow like a sleepy turtle
I wonder why your temperature data don't have decimals?
Krister
