dafuser,
Use the rain_1hr.php in an image tag, like in the directions above.
<img src="wx/wxgraphs/rain_1hr.php" />
And if you are getting a file not found error (I am too) then make sure the file is there. If it is there it may not work but you should not get a file not found error.
I deleted the wxgraphs and jpgraph-1.22 directories. I downloaded fresh copies and uploaded them to my web site. I put test.php and hardpath.php in wxgraphs and jpgraphs/ttf/
http://www.lesdiefenbach.org/wx/wxgraphs/test.php - This works fine
http://www.lesdiefenbach.org/wx/wxgraphs/hardpath.php - This works fine
http://www.lesdiefenbach.org/wx/jpgraph-1.22/ttf/test.php - This works fine
http://www.lesdiefenbach.org/wx/jpgraph-1.22/ttf/hardpath.php - This works fine
Both jpgraph-1.22 and wxgraphs can be accessed by my browsers
All my weather files are located in /wx
My graphsconf.php in the wxgraphs folder looks like this:
//where are your clientraw*-files and JPGraph relative to where this file is
//note you should only need to change the jpgraph directory if you do not use standard names
$hostloc = "${/wx}/"; //must have trailing slash
$jploc = "${WEBROOT}/jpgraph-1.22/src/"; //must have trailing slash
My jpg-config.inc.php in the jpgraph-x.xx/src folder looks like this
// TTF_DIR:
// Directory where TTF fonts can be found. Must end with '/'
// The default values used if these defines are left commented out are:
// UNIX:
// CACHE_DIR /tmp/jpgraph_cache/
TTF_DIR /home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/
// MBTTF_DIR /usr/share/fonts/ja/TrueType/
// WINDOWS:
// CACHE_DIR $SERVER_TEMP/jpgraph_cache/
// TTF_DIR $SERVER_SYSTEMROOT/fonts/
// MBTTF_DIR $SERVER_SYSTEMROOT/fonts/
// DEFINE("CACHE_DIR","/tmp/jpgraph_cache/");
DEFINE("TTF_DIR","/home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/");
// DEFINE("MBTTF_DIR","/usr/share/fonts/ja/TrueType/");
I have the aerial font files loaded in /wx/jpgraph-1.22/ttf
I'm calling the images using
www.lesdiefenbach.org/wx/imagetest.php using:
<table class="weather">
<tr>
<td class="data"><img src="wxgraphs/month_hilo_temp.php" /></td>
<td class="data"><img src="wxgraphs/month_baro.php" /></td>
</tr>
<tr>
<td class="data"><img src="wxgraphs/month_winddir.php" /></td>
<td class="data"><img src="wxgraphs/month_windspeed.php" /></td>
</tr>
<tr>
<td class="data"><img src="wxgraphs/month_rain.php" /></td>
<td class="data"><img src="wxgraphs/month_humidity.php" /></td>
I don't see anything but broken images. When I try to view the individual images at:
http://www.lesdiefenbach.org/wx/wxgraphs/month_baro.phpI get this error:
Parse error: parse error, unexpected '/' in /home/content/d/a/f/dafuser/html/wx/wxgraphs/graphsconf.php on line 7
Trying
http://www.lesdiefenbach.org/wx/wxgraphs/month_rain.php gets the same error:
Looks like it can't find the clientraw files for some reason. Line 7 in my files shows it's looking for the clientraw files:
//$clientraw = get_raw("${hostloc}clientraw.txt");
//$clientrawextra = get_raw("${hostloc}clientrawextra.txt");
$clientrawdaily = get_raw ("${hostloc}clientrawdaily.txt");
The client raw files are in my /wx directory
http://www.lesdiefenbach.org/wx/clientraw.txt12345 5.8 4.7 16 26.4 31 983.0 0.0 0.0 0.0 0.000 0.000 24.8 25 0.0 4 0.0 0 0 0.0 0.0 0.0 0.0 -100.0 -100.0 -100.0 0 0 0 14 42 47 Weather_from_the_shores_of_Lake_Granbury-2:42:47_PM 0 0 5 1 100 100 100 100 100 100 100 26.4 26.8 26.7 10.9 5 Dry -1.0 7 7 7 8 8 8 8 8 8 8 8 8 8 8 5 5 5 5 5 5 12.2 7.9 8314.5 1/5/2008 27.2 11.9 26.7 10.9 0.0 7 6 6 7 7 6 5 4 6 5 25.7 25.9 26.2 26.2 26.2 26.2 26.5 26.6 26.6 26.5 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 26.3 10.9 26.1 9.5 0 --- --- 38 0 0 -100.0 -100.0 -100 0 0 0 0 0.0 25.0 22.3 24.9 990.0 983.0 11 14:07 12:47 25.9 11.0 13.6 7.3 7 2008 0.0 1 -1 1 47 32 65 48 23 36 14 44 45 33 0.0 0.0 5.4 !!C10.37g!!
Does this help troubleshooting? It's probably something minor I have messed up.
