cloudy
Author Topic: Dynamic updating WAP site with CSS  (Read 31423 times)
Offline andro700
  • Chuck
  • Watford City, North Dakota
    • Chuck's Weather Page
Re: Dynamic updating WAP site with CSS
« Reply #90 on: December 05, 2008, 02:22:40 PM »
I use Dreamweaver because my wife uses it to plus it is fairly easy to use I think but that is my opinion of course.
Chuck
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
« Reply #91 on: December 05, 2008, 04:22:35 PM »
I'm clueless on tables myself too.
Though I've had a little luck using the new version of Microsoft Expression.
It's pretty .php friendly FINALLY!
Did you setup the NOAA in WD? Did you place %NOAAEvent% in your testtags folder in WD?
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
Offline CNYWeather
  • Professional Trophymaker!
  • Rome, New York
    • CNYWeather.com
« Reply #92 on: December 05, 2008, 04:29:10 PM »
Tony
CNYWeather.com
CWOP: CW2352
WeatherUnderground: KNYWESTM1
http://www.CNYWeather.com
I Make Trophies Too!
http://www.speedyawards.com
  • Mark
  • Snoqualmie,WA
« Reply #93 on: December 05, 2008, 04:39:36 PM »
Does your line in your testtags look like this?
Code: [Select]
$NOAAEvent = "%NOAAEvent%"; // AdvisoriesWarnings
i ask because in your testtags.php, yours looks different than mine.
Yours..
Code: [Select]
$NOAAEvent = 'NO CURRENT ADVISORIES'; // NOAA Watch/Warning/Advisory
$noaawarningraw = '
There are no active watches, warnings or advisories'; // NOAA RAW watch/warning/advisory
Mine..
Code: [Select]
$NOAAEvent = "NO CURRENT ADVISORIES"; // AdvisoriesWarnings
Offline CNYWeather
  • Rome, New York
    • CNYWeather.com
« Reply #94 on: December 05, 2008, 04:56:45 PM »
Here's whats in my tesstags.txt file
Code: [Select]
$NOAAEvent = '%NOAAEvent%'; // NOAA Watch/Warning/Advisory
$noaawarningraw = '%noaawarningraw%'; // NOAA RAW watch/warning/advisory
Tony
CNYWeather.com
CWOP: CW2352
  • Mark
  • Snoqualmie,WA
« Reply #95 on: December 05, 2008, 06:34:31 PM »
Code: [Select]
heres mine..
Code: [Select]
$NOAAEvent = "%NOAAEvent%"; // Advisories/Warnings
Yours is missing the " " before and after the tag
Offline CNYWeather
  • Rome, New York
    • CNYWeather.com
« Reply #96 on: December 05, 2008, 06:40:47 PM »
If that was incorrect then my NOAAEvent in my testtags wouldnt work, correct?
Tony
CNYWeather.com
CWOP: CW2352
  • Mark
  • Snoqualmie,WA
« Reply #97 on: December 05, 2008, 06:52:12 PM »
If your not using that tag for anything else on your site, i would think the way Mine is should work for you. Im no php writer, but i do know there pretty picky on the coding, and if 1 thing is wrong, it wont work right.
have you tried adding the "" before and after the tag?
Offline CNYWeather
  • Rome, New York
    • CNYWeather.com
« Reply #98 on: December 05, 2008, 07:13:36 PM »
i'll give that a shot when I get home. It's been a PITA trying
to connect.  My work connection is junk lately.
Tony
CNYWeather.com
CWOP: CW2352
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
    • Newburgh Weather
« Reply #99 on: December 09, 2008, 02:31:05 AM »
Ok, got this set up and running here: http://www.tristate-weather.com/wapindex.php
How do I get rid of the extra units of measure next to some readings?
Max Temp:  52.2°F F
 at 2:12 pm
Min Temp:  29.8°F F
 at 12:00 am
Hi Baro:  30.180 in. mb
 at 12:00 am
Lo Baro:  29.903 in. mb
 at 8:55 pm
Max Dew:  25.7 °F F
 at 1:12 pm
I know I've seen this issue answered before, but I can't find it. Thank you.
Offline BfdWx
  • Branford Connecticut
    • Branford Weather
« Reply #100 on: December 09, 2008, 02:49:45 AM »
Look at the lines with the readings, towards the end you will see the added F or mb. Just delete that and you should be all set!
Jack
Offline looney2ns
    • Newburgh Weather
« Reply #101 on: December 09, 2008, 04:38:37 AM »
Thanks Jack. Too simple.  #-o
Offline CNYWeather
  • Rome, New York
    • CNYWeather.com
« Reply #102 on: December 10, 2008, 01:26:20 PM »
Well with some help from Mark at Snoqualmie Weather  :D I've finally figured this out.
I'm using my testtags.php file. Thats not gonna conflict with anything, will it?
I'll be playing with these pages now every night LOL
http://www.cnyweather.com/wapindex.php
Tony
CNYWeather.com
CWOP: CW2352
  • Mark
  • Snoqualmie,WA
« Reply #103 on: December 10, 2008, 01:31:16 PM »
No..adding more tags to your testtags will not conflict with your WAP page. Just checked your page...looks good.
Offline CNYWeather
  • Rome, New York
    • CNYWeather.com
« Reply #104 on: December 10, 2008, 01:37:19 PM »
Thanks again Mark.
Tony
CNYWeather.com
CWOP: CW2352
