I’ve developed a problem with my outdoor temp display on the main screen. It’s stuck at 62.2 F since I updated to 9.89B afew days ago. I’ve since tried V9.89D with no change in problem. Watching the display, the temp (and other values, Barometer, Wind direction) will change for a split second to the correct values, then back to the “stuck” position. All the other graphs, extreme values reflect the correct readings, just the current display is incorrect.
I’ve rolled back to 9.88d (last good version) and tried latest v9.90 with same results
XP system, 2.4 GHz Pent., 768M Ram
Any help is appreciated.
Randy
KK6RW
