I am using a Davis Monitor II and rainfall has not been showing up on the display. Just yesterday we had almost 4" rain and the Monitor II indicated the rain amount but the WD display still shows 0" for the entire year while the Monitor II indicates 551.6.
Running 9.84c on a Win98SE system that feeds an APRS Digi & Igate.
check your settings under weather station type, davis rain collector type, is set correctly (and that you are using a davis wmii full for station type)
also, note that WD stores it rain totals separate from the station (so you can set a more configurable reset time, etc)
to set the start values, do that under setup, barometer offsets and rainfall…
there must be something a miss somewhere, as normaly it works just fine with the davis wmmii rain
