one real important thing .. don't touch the plastic white"button" . oil from your skin affects that. Now if you did... you need to clean it with ethanol alcohol.. Rubbing alcohol won't work.
Either get some Ethanol ( Ethyl alcohol) at the druggist or some 100% alcohol.
The sensor is supposed to be perpendicular with the zenith, but it can aimed. That aiming gives the parabolic curve appearance of the reading.
