Any plans to support Meteobridge
I am using the AcuRite internet bridge with a 5 in 1. The bridge crapped out on me. 2 weeks to send and receive a new one back. Then my pc crapped out on me. I could not for the life of me create a bridge again to use Kevin keys bridge reader with the new pc and clean install of windows 7. Gave up and bought a D-Link DIR-505 and flashed Meteobridge with a license. Working perfectly. Uploading to WU, PWS and CWOP no problems. The Acurite stuf is very limited to the software that can be used with it. I was outputting the data to a CSV file through Kevin Keys bridge reader that WD read. Do you have any plans to support Meteobridge?
Vinny
HI
WD already supports the meteobridge
you set that up in the com port setup
Com port 1 is the only one available and selected. Under TCP/IP Connection to Davis VP/Vue IP /VVP/Meteohub I put the IP to log into Meteohub Port 1 and checked use with Meteohub. No option for Meteobridge.
When I click on Show connected devices I get this error:
GetAdaptersAddresses failed with error #87
Vinny
the meteobridge should behave the same as the meteohub
the show adaptors is not relevant to your device
what shows under view, debug info
station/setup data reports
Program debug info:
Daylight saving in use
Loaded all time records
Vinny
humm
it should info about accessing meteohub
post a screen shot of the meteohub settings from the com port setup
or .zip and email me your settings files (see the FAQ on how to do that)
I didn’t have (enabled) checked off along with (use with meteohub). The meteohub data access: line just keeps repeating. Also when starting WD a current status windows pops up. Getting missed data. Just keeps saying increase time.
This is what I’m getting now under debug info:
Date /time (PC) that WD was last running is: 06/19/2015 16:43:00
converted to UTC Date /time that WD was last running is: 20150619204300
getting missed data initial 20150619204300 20150619204400
[10061] Connection refused
meteohub data access:->http://192.168.29.246:1/meteolog.cgi?mode=data&type=xml&start=20150619205900&end=20150619210000
Vinny
the problem is the [10061] Connection refused
error
are you sure you have the port number set correct?
The command used is invalid. There should be no port (or the default port 80) specified
http://192.168.29.246/meteolog.cgi?mode=data&type=xml&start=20150619205900&end=20150619210000
But this is a METEOHUB command not supported by Meteobridge.
And as Meteobridge has no storage for detailed weather-data I think it can not accept a timeframe for historical data anyway either.
Meteobridge WiKi: http://meteobridge.com/wiki/index.php/Add-On_Services
The correct meteobridge url should be
meteobridge:[email protected]/cgi-bin/livedataxml.cgi
which returns data such as:
<logger>
  <TH date="20150622151420" id="th0" temp="14.7" hum="90" dew="13.1" />
  <T date="20150622151432" id="t1" temp="25.0" />
  <TH date="20150622151432" id="th1" temp="25.0" hum="0" dew="25.0" />
  <TH date="20150622151432" id="th10" temp="14.4" hum="48" dew="0.0" />
. . . shortened . . .
 <WIND date="20150622151459" id="wind0" dir="221" gust="1.3" wind="1.8" chill="14.7"/>
 <RAIN date="20150622151432" id="rain0" rate="0.0" total="187.0" delta="0.0"/>
 <THB date="20150622151436" id="thb0" temp="21.6" hum="40" dew="7.4" press="1002.0" seapress="1006.7" fc="0"/>
</logger>
The Meteohub command as used above returns similar data but a little different, no quotes and no proper end />
<logger>
  <THB date=20150622152950 id=thb0 temp=23.1 hum=49 dew=11.8 press=1002.2 seapress=1006.3 fc=0>
  <TH date=20150622152938 id=th0 temp=14.6 hum=88 dew=12.6>
  <T date=20150622152950 id=t1 temp=25.0>
  <TH date=20150622152950 id=th1 temp=25.0 hum=0 dew=25.0>
  <TH date=20150622152912 id=th10 temp=14.4 hum=48 dew=0.0>
  <SOL date=20150622152936 id=sol0 rad=265>
  <RAIN date=20150622152950 id=rain0 rate=0.0 total=230.4 delta=0.0>
  <WIND date=20150622152946 id=wind0 dir=224 gust=0.9 wind=1.8 chill=14.6>
  <DATA date=20150622152928 id=data1 val=2660309.00>
  <DATA date=20150622152928 id=data3 val=0.73>
  <DATA date=20150622152928 id=data2 val=1.00>
</logger>
I hope this helps a little bit,
the IP setup should not contain the port number
just the IP only
as WD adds the port number
so maybe that is the problem there
I never added the port number in the ip address. 1 was selected by default
and is the only com port available according to WD. I just put 192.168.29.246
with 0 and also backed spaced 0 out but WD keeps adding 0 back in. I also tried
Wim van der Kuil’s ip suggestion.
192.168.29.246
all above ip’s lead to this in debug info:
getting missed meteohub data 20150624182400 20150624182500
OK
Not Found
OK
and a rapidly flashing message that cannot be read because it is flashing to fast.
I have to unckeck enabled and restart WD. Then on restart with enabled unchecked
under debug info:
OK
Not Found
OK
( connected OK to com port 1 ) only appears under debug info after enabled is
unchecked and WD is restarted.
I ran Advanced port scanner.
Under 192.168.29.246 ports (scanned 67 of 67, opened:3 closed:64)
open ports (3)
22 open (ssh)
53 open (domain)
80 open (www-http)
closed ports (64)
0 - 21 closed
23 - 52 closed
54 - 79 closed
81 - 65535 closed
Vinny
the not found error points to the IP address not being correct somehow
can you post a screen shot of the com port setup , meteobridge setup?
also have you tried build 81?
thanks
I also sent the settings files.
that port number being set to zero will be problem
I only tried 0 because the default 1 would give the same error. 1 is the only port available according to WD.
how do you mean only 1 according to WD?
the port number is often like 80 or 8080
The port you should use is 80
You can select that by using the scroll bars or type the value.
At least that can be done at my version 81.
com/ip port
comm port setup
com port 1 selected by default and only port shown as available
Please bear with me on this not understanding this at all. Apparently I’m confusing com port and port numbers.
I only looked under comport number because of the info under debug info.
getting missed meteohub data 20150623182900 20150623183000
OK
Not Found
OK
As for using port 80, this is what I get with port 80 under debug info
ip address vp/vue ip data logger
port number
80
192.168.29.246
port number
80
under debug info with both above settings
OK
Not Found
OK
I have the latest build installed. Port 80 was the original setup and didn’t work.
port number
80
192.168.29.246
port number
80
under debug info both scenarios above
OK
Not Found
OK
Vinny
I think it can work. The xml packages are quite similar.
Only Meteobrisdge needs a userid:password@ before the ip-address. Meteohub does not need that.
As I said Meteobridge does not support historical data. It has no memory, as only Meteohub has local memory to store historical data.
So the message “Not found” is the logical conclusion WD for the missing historical data. But they can also be missing for other reasons, so WD will be used to stations not supplying missing data.
Then it connects again to the Meteobridge using WD-internal-port1 (which, i think, is connected to => 192.168.29.246:80)
So what happens after “connected OK to com port 1”
The question is: Is there any data arriving in WD ? Is the dashboard showing data for temperature and so on?
If it does not show any data, try to add that userid:password@ part before your 192.168.29.246 and see if the data is shown then.
And very soon Brian will wake up again on the other side of the globe to help you further.
