cloudy
Author Topic: vp2 usb driver update  (Read 38286 times)
Offline dave7101
  • Southern Ontario - Kitchener/Waterloo Region
« on: August 01, 2007, 05:32:28 PM »
I upgraded to the USB v5.0 driver found here
Driver: CP210x_VCP_Win2K_XP.exe (= VCP Driver Kit)
http://www.silabs.com/tgwWebApp/public/web_content/products/Microcontrollers/USB/en/mcu_vcp.htm
and it works flawlessly, perhaps a fix once and for all, for the davis vp2 usb hang/disconnect issue.
Using XP Pro SP2
Offline Tayac
  • Tayac, St. Pantaly d'Excideuil, 24160 France
Re: vp2 usb driver update
« Reply #1 on: August 06, 2007, 06:00:55 PM »
Hi Dave,
I'll give this a try; lots of problems with my USB logger suddenly stopping sending data to WD.  Let me know if you encounter any future problems with the patch and I'll do likewise.
Cheers,
Steve
« Reply #2 on: August 06, 2007, 06:03:29 PM »
this is a winner, lots of other great results reported by other people on other forums etc  :wink:
Offline Heuer
  • Nottingham, Great Britain
« Reply #3 on: August 20, 2007, 11:49:02 AM »
This driver causes a Blue Screen of Death on some systems. I suggest you avoid it for the moment or be prepared for possible data loss and corruption!
Davis VP2+ and Envoy,
Offline Heuer
« Reply #4 on: August 22, 2007, 09:16:59 AM »
Not only does the V5 driver cause lock up problems my AVG anti-virus scanner has shown a number of Trojans associated with the install. Not sure if they are false positives but worth running a check if you have installed this.
Offline Tlowe
  • Minneapolis, MN, US
    • Carman Bay, Lake Minntonka, WX
New USB driver for Davis VP2 - v5.0
« Reply #5 on: September 25, 2007, 06:25:31 PM »
There is a new USB driver available for the VP2 from Silicon Labs. This version (5.0) seems to work much better than 4.4. WD has not hung up since I installed. Mine was hanging  everyday previous to this version. Davis told me thay would swap my USB logger for a serial if I continued to have problems with this driver. I'm running Vista Home Premium.
Online TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
Re: New USB driver for Davis VP2 - v5.0
« Reply #6 on: September 25, 2007, 06:42:06 PM »
This does not appear to be new.... Please see:
http://www.weather-watch.com/smf/index.php/topic,25856.0.html
Offline Tlowe
« Reply #7 on: September 25, 2007, 09:16:25 PM »
Sorry, didn't see this thread, I posted in another section & a moderator must have moved it over here. Working flawlessly for me, so far. Definitly an improvent over v4.4 for me.
« Last Edit: September 25, 2007, 09:18:00 PM by Tlowe »
Offline Tlowe
« Reply #8 on: October 05, 2007, 01:12:34 AM »
Running solid for 9 days now without a hitch. The new driver is working great for me.
IT Farmer
  • Guest
« Reply #9 on: November 15, 2007, 01:17:03 AM »
I could not get it stable under Vista, it locked up after one day.
Offline Tlowe
« Reply #10 on: November 15, 2007, 01:45:23 AM »
Mine has been running about 100 days straight, without a single error. PC has never even been rebooted, not once in all that time. So it must be machine specific. My Vista is fairly clean, on a dedicated laptop.
« Reply #11 on: November 15, 2007, 02:30:02 AM »
i did see a report that it could be things like flourescent light bulbs that cause problems with the usb connection even....which is why replacing the mini USB cable with one with RF chokes at each end has helped out
Offline Weather-Ham
  • Pontefract, West Yorkshire
« Reply #12 on: November 20, 2007, 04:56:31 PM »
 :lol:
Hi All,
Been running for a week now with the new driver, no blue screen, no dropping the link etc.. this is good
Also Running Win XP SP2
 :salute: :salute:
« Last Edit: November 20, 2007, 06:46:13 PM by Weather-Ham »
Offline zeppline
  • Las Vegas, Nevada
    • Las Vegas Weather Guy
« Reply #13 on: November 20, 2007, 10:29:05 PM »
Followup
I had problems when ver. 5 first came out blue screen and lockup. I think there was a problem with ver 4 and ver  5 on my machine at the same time. When I installed ver.5 I though it would remove ver.4, it did not. so I removed ver.5 everything worked. This time I removed everthing with device manager for ver.4 and re downloaded ver 5 and installed it. Everthing has been working good for about 60 days.  Joe
warwickpaweather
  • Guest
« Reply #14 on: December 22, 2007, 11:18:35 AM »
I also had the USB disconnect/lockup problem. I called Davis and they exchanged my USB with a serial version. Works without a problem.
