Hello.
You have put a lot of work into this and i hope you see this as a constructive comment.
I think the rain bucket would be OK in its position but not attached to the mast but bolted to a pole into the ground.
The screen with the temp sensors could be brought closer to the mast and make it more stable.
It just looks like there is a lot going on up there.
I just wonder, as others have said, if it will be stable enough.
Much of the time things are easy er on paper than in practice.
Edit. Lew There is a big long thread 'Post a Picture of your weather Station'
I realize the temp sensor could be closer...there is no shadow issue with it. There is nothing about the sensor though that would be sway sensitive is there?
As an aside, I was reading somewhere about keeping the temp/humidity sensor away from metal pipes...perhaps that was something in regards to my Honeywell that isn't applicable to the Davis? Seems since the Davis was made to mount on a steel pipe that it doesn't matter to it.
The point of attaching everything to the common post was so it could be moved up and down seasonally and for mowing, and gave a way to connect the cable (inside the pipe) between the mast and the bucket. With my design the included 40' cable will reach it. I didn't want to have two posts with the wire running in the air between or have to go down to the ground, through a trench, and back up the other post.
My goal was to come up with an install as close to a CWOP score of 30 and be all on one mast for simplicity. I was also hoping to keep it close enough to the house so I could run a AC cable out to it in the winter for a bucket heater. That is why I might install it where my current station is vs. north of my place past the pond.
I would be curious who has achieve the highest CWOP score on a single pole? Does anyone else have a single pole install who has come up with another method? Based on my recollection you lose 2-3 points with a stock Davis bucket on top design because you either lose points for having the temp too low or the bucket too high. That is even with mounting the anemometer separately.
There is a large flag pole manufacturer in the industrial park a mile down the road from me. I am considering seeing what they have on hand for poles, perhaps some "seconds" or rejects. A flag pole has a huge windload and no guy wires, not that they don't sway at all, but most of them don't sway much at all.
Thanks!
Lew
