Author Topic: Printer error (run time error 482)  (Read 3889 times)
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« on: July 12, 2007, 09:33:34 PM »
I am trying to move my WXSim installation to a different PC and having installed the demo and then copied over all the folder data WXSim will not start because of the above error. Now this PC does not have a printer installed and is never likely to as it has none connected. How can I get past this error and get WXSim up and running?
Offline daveq
  • Hollywood, MD
Re: Printer error (run time error 482)
« Reply #1 on: July 12, 2007, 09:54:12 PM »
Stuart, a search for that error shows that several programs require a printer to be installed.  Maybe because you can print out WxSim info it's looking for a printer driver???
Do a search on Google and you'll see more.
--Dave
Offline JaxWeather
  • Bob
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #2 on: July 12, 2007, 10:17:47 PM »
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #3 on: July 13, 2007, 05:25:03 AM »
Yes I saw that thread but I was hoping that I did not have to install something which will never be used. I just dont think it right that just because you CAN print from a program that you HAVE to install a printer, if you dont use the print function it should not require a printer. I was hoping Tom might come up with another solution.
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #4 on: July 13, 2007, 06:41:03 AM »
I've now installed a generic printer and WXSim starts up OK. This still bugs me as I dont think I should have to do it!
Offline Tom Ehrensperger
« Reply #5 on: July 13, 2007, 11:11:57 AM »
Hi Stuart,
Yes, I've heard of this one a few times over the years.  You do need to have a "printer installed" (really just meaning a generic one declared by going to Control Panel/Printers and Faxes, and declaring one, I think).
This is one of those things totally beyond my control.  Visual Basic and/or however it's interfaced with Windows apparently thinks that if there's a print command anywhere in a program (and I certainly want to keep printing options available), it had better make an error of it, even if you didn't try to print!  Thankfully, it has an easy solution, but I agree it's kind of goofy.  Maybe there was a good reason for it somewhere, sometime.
Hope that helps!
Tom
