try it out for size (up to 50 positions available)
(new WeatherD.exe and new wdmysql.exe needed)
http://www.weather-display.com/downloadfiles/WeatherD.zipnote, if you use say the %time% and %date% custom tags.....for time and date...then instead just enter say time and date as the tags...but as long as you have set the data type to be time and date respectively, then the time and date at the point of data update to the database will be used (gets away from probem of am/pm stuffing up the space delimited file)
some info:
custommysqlin.txt, in the clientraw folder location (default is the webfiles folder)
is the file with the custom tags, updated auto by the wdmysql program after click on OK in the custom setup, and is based on the custom tags setup
custommysqlout.txt is the file used with the custom tags parsed into data
good luck
(make sure you set up your table to match the datanames and data types setup)
