I run Vista and WD and do not have any issues, I used to have but this was either other
program conflicting or my memory was causing issues..
Just remember, Vista needs at least 1gb of ram so to smoothly run anything on Vista i would
recommend 2GB.
I dont even have WD running in compatability mode, what i will say is there are some issues
with the webcam side of things, Sometimes Vista will go into basic mode with the webcam side
of things are running but this happens only when i put load on the PC.
Also theres some issues with the alldayvideo creation, but as i have not played with this properly
i cannot be any less vague, as soon as my new camera comes i will look into it some more
it might just be the WME v9 still having issues....
As it stands, without the webcam in use at present there are no issues with WD and Vista
Your system will more than likely be different to mine and will more than likely work fine.
I have many other programs running that could and more than likely does cause me issues!
None of these are questions Brian, I am just letting Fabry know what "might" occur
